I hope everyone is staying safe and healthy!
I am trying to get some loose ends tied up and start driving my 914.
I need a recommendation on primer to use for touch up where I have had to grind or drill or weld on my 914. These are all places that are not usually visible and I am not worried about their looks, I am after something to protect the bare metal. I only need small quantity and application with a brush would be easiest.
When I bought this 914 it had been stripped and repainted but I have had to fix some things.
Most of the holes for the windshield trim clips had been welded up. (I don't know why?) So I had to grind through newish paint to locate some of the holes and drill new holes as needed. I need to prime the bare metal before I install the windshield.
I'm in CA and I have already attempted to get some pinch weld primer for butyl but it is no longer sold in CA.
I have some touch up to do in the engine compartment where the trunk hinges were broken loose and required repair. Who would paint a 914 without fixing the torn trunk hinge mounts?
I had to grind body filler out of passenger side of the front trunk seal channel around the head light bucket. They had so much filler the seal would not fit in the channel. Of course when I ground through the filler in the channel I found rust under it and had to clean that up.
There ares some other small places that need primer as well but it is all small stuff.
Thanks
Jim
