@SKL1 date='May 26 2020, 07:29 PM' post='2819384']
Figured if I blocked them off it would allow more cooling air to go to the oil cooler and cylinder fins instead of just out to the atmosphere under the car. I realize if you still have the heating system and it is off it eventually just vents outside anyway but figured anything could help an AC'ed car, especially in Arizona!!!
[/quote]
Just blocking them off will have a negative effect on cooling. Think about what happens when air is blown into a blind hole.
Do you run an oil temp gauge? It you can hit over 250 under sustained griving you need more oil cooling.
