I have a complete set of shift linkage that is needed to convert to a side shifter.
you would still need:
-new motor mounts (rubber)
-a rear shift console plastic cover (914 rubber)
-a forward shift plastic cover (914 rubber)
-new shift linkage cone screws x2 (new)
-a conversion firewall shift bushing, plus the 2 rear bushings (new)
-replacement bushing for the fire wall connection knuckle (new)
-the warm air guide for a side shift, if you want all stock tin in place (car will run without this piece)
-a side shifter transmission, or change the tail cone and rods on your tail shift
This sale includes:
-both forward and rear shift linkages for a side shift
-the actual shifter that is necessary for SS
-the bushing in the bottom of the shifter, to mate to the shift rod (not in these pictures but included)
-the motor bar that is for a SS
-both motor mount brackets, required to use the SS motor bar
-front and rear shift linkage attachment hardware to connect the bars at the shifter and shift console (front splined piece, and rear cup)
-the aluminum flex knuckle for the fire wall connection
I can also provide the SS tail cone and internal shift rods for converting your tail style transmission. I can provide these to the buyer for an additional $150 as part of the package
The complete shift linkage is in good shape
due to the motor bar, its a heavy package to ship
I've been doing actual shipping cost, since rates vary depending on distance.
so Shipping would be actual cost at UPS (I shipped a lighter tail shift package for 36, so this would be more, due to the length of the motor bar and weight)
complete shift linkage conversion package: $400 + actual shipping
SS transmission tail cone and 3 internal shift rods $150 optional to the buyer, not willing to split (will need to get pictures if buyer has interest)
let me know your questions
brant
