QUOTE(rjames @ Sep 5 2020, 02:17 PM)
I just spent the last 2 summers get my DJet back in running order and may be able to help.
That said, give as many details as you can and maybe with everyone's help here it can be a remote fix.
OK-here's the list.
Injectors rebuilt by Witchhunter, but one always left a plug wet, so it has recently been changed to a NOS one
AAV tests good, as does the MPC. New TPS set with an ohm meter. New gaskets and sleeves on the intake manifold, new vacuum hoses.
Fuel pump tested at 28 pounds. Compression over 125 on all cylinders. Valves set.
New Pertronix, cap, rotor and wires. Timing set properly at full advance. Trigger points looked really good and were checked that they were contacting. New connectors on injector wiring harness.
ECU is set 11 clicks from full stop left.
Car is hard to start, and seems to flood. Just put a clamp on the cold start injector and it seems to start easier. Need to get it out on the road to clear it out.
My latest thought is the cold start injector is on all the time or bad or leaking. Taking it out of the system seemed to help but the car is so loaded up with fuel it will take a while to get it to run clean.
Any other ideas? I'm really to the point where I think it needs fresh eyes on it.
Thanks-
