Full Version: J tube block off cap
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
brant
an original, J-tube cap for the heater system
not cracked, clean condition
$6 shipped in the US
Gint
brant
Nice.
does the -6 use them?
BillC
I'll take it! PM incoming.
nditiz1
Can you get me the inside and outside diameter? Wondering if this will fit the backdated heat pipe off the fan shroud (drivers side)
Gint
They fit over the J tube that comes up through the engine tin from the heat ex changers. If you don't have a auxiliary electric fan, you use these to cap off the J tubes. So whatever size that J tube is, the inside diameter of the cap needs to fit over, and not necessarily snugly. They are typically fitted with a hose clamp, which is why they have two slots. Getting an accurate inner and outer dimension on a 50 year old plastic cap is a bit of a crap shoot, but...
2.13" inner (54.2 mm)
2.37" outer (60.3 mm)
