QUOTE(jim_hoyland @ Oct 19 2020, 04:26 PM)
QUOTE(914sgofast2 @ Oct 19 2020, 09:45 AM)
I bought a 1970 model year 914 that had been sitting in a barn since 1988. We had to replace all fuel hoses and the fuel filter; then replaced all 4 fuel injectors because they started leaking shortly after it started running. Replace thr spark plugs, but before uou indtall the new ones swiirt some ATF into each cylinder snd crank the engine over eith thr new battery you just had to install.
That's good info. I'm going to make up a step by step guide for the owner. Things we take for granted, like removing and cleaning the fuel tank and related parts require detailed "how to" info.
I'm bumping this to the top because if Jim is going to be kind enough to put together a list (and hopefully share it) let's see what the collective can add to help make it comprehensive and helpful. I know a lot of people would find this useful. I'll add two random thoughts: check the tires for dry rot and flat spots. Check the date code on the tires and replace even if the look good if they are over 8 years old. I know replacing the fuel lines has already been said, but adding more information about how much and what type of fuel line is needed, etc...
