Parts List:
Engines/Engine Mechanical Parts
1975 2.0 GC Case - Good Condition - $400
1973 1.8 EC Case, Crank, Rods, Cam and Oil Pump - Good Condition - $300
1.7 Long Block with heat exchangers (Complete Engine minus carbs, intake, distributor. Unknown Condition, Spins Freely - $600
OEM Oil Cooler - Good Condition - $40
Engine Tin (1/2 Side Tin - 3 1.7/1.8 $40/each, (4 Rear Tin, $40/each), (Misc. Tin, $10-20/each). Condition ranges from fair to good.
Thermostat - $50
2.0 Air Cleaner Housing - Surface Rust, but overall good condition - $40
SOLD - OE Oil Pump - 021 115 109A - $30
Oil Filter Mounting Console - $30
SOLD - 2.0 Oil Pickup and Windage - $40
SOLD - 1.7/1.8 Heat Exchangers (smoke tested ok) - Good Condition - Surface Rust and Paint, but solid - $150
1.7/1.8 Heat Exchangers (smoke tested ok) - Fair Condition - Surface Rust - $80
1.7/1.8 Stainless Steel Heat Exchangers (smoke tested ok) - Great Condition - $400
2.0 Heat Exchanger (smoke tested ok) - Passenger Side - Fair Condition - $100
SOLD - 1.8 Heads - Good Condition (No Visible Cracks) - 021 101 371 S - $120 (Set)
2.0 Heads - Bare - 1 Head Great Condition (no cracks), 1 Head Machining Needed (Valve Seat Damage, 1 broken fin and 1 bent fin) - $350 (Pair)
Cooling Shroud (Good Condition) - $100
Cooling Shroud w/Alternator - Good Condition (small crack) - $100
Aftermarket Muffler - $75
A/C Compressor (York) Stock (unknown condition) - $40
1.7 (2 sets)/1.8/2.1 Cylinders (90 (2 sets) /92/96mm) - 92mm Cylinders and 96mm Cylinders SOLD, Pistons and Pins (most cylinders in good shape-all need to be honed. A few pistons have gouges and nicks. Pins would need to be polished) - $80 for entire lot
Pressure Plates - $20/each
SOLD - Flywheel - $40
SOLD - Connecting Rods - $40
Camshafts - $30/each
Crankshafts (Don't know for which motor) - $40/each
SOLD - Smog Pump - $40
SOLD - Engine Parts Lot1 (rocker arms, lifters, pushrods, springs, gaskets, etc) - $50
Engine Parts Lot2 (motor mounts, etc) - $50
Engine Support Cross Bars - $60 for early style, $100 for later style
SOLD - Early 2.0 Muffler Bracket - $20
1.7 & ('74 1.8) Muffler Bracket - $20
Engine Electrical Parts
SOLD - Bosch Blue Coil - $20
Heater Blower Motors (TESTED-WORKING)- $80/each
Relay Board - $50
Alternator (with Cooling Vent) - $40
Transmission Parts
Shift Rod Linkages (3) - $25/each ($0 for broken one)
Interior/Mechanical
Shifter - $50
Seat Bracket - $40
Interior
Passenger Door Pulls - $30/each
Driver Door Pocket (Blue) - $20
A-Pillars - Poor to Fair Condition - $20/set
Ash Tray - $20
Driver Door Pocket Covers - Fair Condition - $20/each
Rear View Mirror - Fair Condition (Glass Issues) - $20
Upper Windshield Trim - Fair Condition - $20
Carpet Sill Trim Lot - $20
Seat Belt Receivers - $25/each
Misc. Interior Vents - $20
SOLD - Pedal Board (Decent Condition) - $40
Dash Trim Plate - Very Straight - $20
Center Console Shifter Panel/Trim/Cover & Defrost Switch - $20
Console Box (Fair Condition) - $20
Body/Electrical
Tail Lights (2 lefts, 1 right) - Poor to Fair Condition (usable) - $20/each
Front Turn Signal Housings - Fair to Good Condition - $20/each
Horn - $20
Fresh Air Box and Fans - $100/each
Windshield Wiper Motors/Headlight Motors and Windshield Wiper Linkage - $40/each
Headlight Assembly Lot - Fair Condition - $60
Fog Light Grill - Poor to Fair Condition (2 Cracks) - $20
A/C Evaporator, Fan and Enclosure DPD - $40
Misc. Relays, Switches, Actuators (Unknown Condition) - $20
Rear License Plate Lights - $20
Body
SOLD - 1973 914 Rolling Shell - Mainly surface rust. Hellhole, Rockers, Longs, Floors, Battery Tray, etc. solid. Small hole in floor, battery tray, spare tire well and trunk. Left Rear Shock Tower Needs Replacement. Has suspension, 5 steel "sport wheels", passenger windows and mechanism, etc. - $600
Engine Compartment Covers - $40 (white one is SOLD)
SOLD - Engine Compartment Cover (Complete) With Rain Tray (Great Condition-No Dents) (Early Model) - $250
Rain Trays (2) - Both Have Small Cracks (can be fixed easily) - $80/each
Targa Top (Good-Usable Condition - w/Front Latches) - $125
SOLD - Targa Top (Good Condition - w/ 1 Front Latch) - $125
SOLD - Front Hood (Great Condition - no dents, light surface rust, latch) - $125
SOLD - Dash Frame (Good Condition) - $80
SOLD - Front Bumper (Chrome Painted Black - Fair Condition) - Fairly straight with only a few dents- $80
Windshield Trim (Poor Condition - Mostly Bent) - $0
License Plate Bracket - $20
Bumper Guards (Good Useable Condition) - $20
SOLD - Rear Valance - poor to fair condition - $20
Spare Tire Well Section - $20
Brakes
SOLD - Rear Calipers (Good Condition-Needs Rebuild) - $30/each
Rear Backing Plates - Fair Condition - $15/each
Front Backing Plates - Good Condition - $20/each
Suspension
Aftermarket Unknown Brand Springs - Very High Spring Rate it Appears (Pair) - $40
SOLD - Weltmeister SP100 Rear Springs (Pair) - $60
Stock Rear Springs - 3 Red Stripes (2 Pair) - $20/each pair
Spring Hats, Seats & Hardware (Lot) - $25
Rebuildable Rear Bilsteins? 2 of them seem to work ok - $20/all
Tie Rods - $20/all
Front Suspension, uprights, spindles, backing plates, crossmember - $100
Glass:
Driver's Window - Good condition - $60
Rear Glass - Good condition - $60
Misc.
Fuel Tank - $40
Fuel Tank Bumpers - $10/each
Windshield Washer Bottles - $20/each
Fuel Expansion Tanks (1 Plastic, 3 Metal) - $20/each
Wiper Arms Lot - $20
Charcoal Canister (2) - $20/each
Hood Springs and Hinges - $40
Factory Lug Wrench - $20
Thank you for looking!
PICTURES ARE HERE!
http://paulmichaelrogers.com/porsche914parts/
Paul
