QUOTE(Tdskip @ Jan 23 2021, 08:54 AM)
First of all thank you for all of the help and responses. I hope everybody had a good week.
When I unscrew what Brock circled I do not have a nipple/fitting for a vacuum line, it’s just open.
The link to the Del shop that
@rfinegan with the threaded part number 71 looks like the ticket, I’m assuming the threads on a dell will be the same on a Weber or EMPI?
I'm not sure I'm understanding. The end result is essentially the same with either version. You just need to get a hole into the right location on the carb you can attach a vacuum hose to. I think the only real diff between the del and weber versions is that the del threads in vs a press fit. Here's might with screw plugs removed and hoses attached.
