Full Version: FS: Parts lot
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
partwerks
For sale: Parts lot
All used parts.
Cash if local pickup, or paypal if being shipped.
Shipping on top of stated price.
1. Relay board-came off of a running car, but has been sitting out in the elements for about 3 months, but very little moisture during those months. $42.00
2. Front hood hinges & springs-$41.00
3. Rear deck lid hinges-$20.00
4. Trunk torsion bars & clamps-$25.00
5. Window crank-$1.00
6. Hood release cable (no plastic tube) $25.00
7. Trunk light-$5.00
8. Relay board cover-has cut/crack on top, and a piece of corner broke off-$1.00
Knob, and bolt are SOLD.
9. Battery hold down clamp-$2.00
10. Front targa latches-one has a good handle, but bent hook, and the other one has a cracked handle, but good hook. Can make one good handle out of them both. $18.00
11. Front lower hood latch-$31.00
12. Used 200# springs-$40.00-SOLD
13. Dog bones, two-$10.00-SOLD
14. Clutch stop-$4.00-SOLD
15. Fuse box-$9.00
16. Fresh air vent tube grommets (pair) $5.00
17. Brake reservoir-$4.00-SOLD
18. Tripometer cable-$15.00-SOLD
19. Window channel sealing rails-one rail has two holes that are over sized-$15.00-Sold
20. Driver side vertical rollbar pad-$10.00-SOLD
21. Glove box locks (2) A bit rough around the front. One is complete, the other isn't-$20.00-Sold
22. Trans ground cable-$2.00-SOLD
23. Windshield pillar pads-has some material missing in the corners-$30.00-SOLD
24. L defroster duct-has inner tab broken off-$10.00
25. Control box pieces-Control box has some metal bracket parts broken off sides. Otherwise all have the tabs intact-$22.00
26. Clutch cable bracket w/bushing-$5.00
27. Clutch cable clevis-$5.00-SOLD
28. Pedal board hold down clamp (Pyramid shaped) $1.00-SOLD
29. Fuel pump bracket-$5.00-SOLD
30. After market rear swaybar-$50.00-SOLD
31. Steering column. Missing small screws for ignition switch retainer bezel around ignition lock on the front. No key. $114.00
Literati914
I'm interested in the aftermarket rear sway bar - can you get me shipping to 75233? THX.
frostyf
Couldn't see the a frame pads:
And keen to get the
Can I go 2nd for the rear sway bar if literati passes?
Thanks,
Nick
PS Shipping to VA 23455
ndfrigi
edited: since someone already ahead of me for #23
interested with #18 and 27. quote shipping to 90680.
thank you!
partwerks
QUOTE(Literati914 @ Feb 7 2021, 03:57 PM) *
Yes.
Literati914
.. besides the rear sway bar(30), I'd also like the fuel pump bracket(29) - thx.
partwerks
QUOTE(Literati914 @ Feb 7 2021, 04:05 PM) *
I made a note of it.
partwerks
QUOTE(frostyf @ Feb 7 2021, 04:03 PM) *
And keen to get the
Thanks,
Nick
I swapped out one picture for a close up of the WS pad. It's the last picture.
cork
i'll take the ground strap and dog bones, please send PayPal info Thanks
partwerks
Bump
StarBear
I’ll take #8 cover with post and knob. Will pm with address and zip.
partwerks
Bump
ClayPerrine
Just a note to whomever bought the rear sway bar. The aftermarket bar in the picture will not fit the stock factory sway bar mounts. I recently bought one just like it and found this out the hard way.
Clay
B2524
Ill take the 200lbs springs
PM PP info and total
Ships to 93465
rgb91424
I would like the clutch stop for pedal board #14 and the pedal board retainer #28
I don't do pay pal. How about USPS money order ? Shipping would be to 86401 Az.
Thanks Bob B.
partwerks
Bump
partwerks
Bump
partwerks
Bump
mgp4591
PM sent.
56kabrio
QUOTE(mgp4591 @ Apr 7 2021, 06:38 PM) *
PM sent.
I'd like the a pillar pads and the roll bar pad if they're still available'
Thanks
Mack
Medtner3
any chance you have another relay board cover with nut/bolt
partwerks
QUOTE(Medtner3 @ Apr 9 2021, 07:00 PM) *
No I don't. Just have the cover, and not in the best of shape.
