JamesJ
Sep 17 2021, 08:38 PM
Hello All,
My '74 1.8 car has an ignition coil bracket with two holes in it. One is round and the other is square. I believe it to be original. Can anyone tell me if this is an original bracket and what the holes are for?
Thanks,
James
Click to view attachment Click to view attachment
wonkipop
Sep 17 2021, 09:10 PM
yes, thats an original coil bracket.
never had to change the coil on mine.
far as i know the holes do nothing and have nothing through them.
the black orig coil on mines got nothing on it in terms of bumps or engaging pins.
dunno why they had the holes.
when you look at a kombi or type 4 its not clear why the holes are there either.
someone may know.
ndfrigi
Sep 17 2021, 10:31 PM
914Sixer
Sep 18 2021, 08:17 AM
My guess is it was an off the shelf item used on another VW product.
NARP74
Sep 18 2021, 12:07 PM
Side note: what hardware is used to mount that coil? I think it is M10 1.0 but what length and head configuration? Any washers, what type? Thanks
It took me many months to find one of those for my project...
bdstone914
Sep 18 2021, 12:18 PM
QUOTE(NARP74 @ Sep 18 2021, 11:07 AM)
M6 bolt with a flat washer and lock washer. I like to use an allen head bolt as it is hard to access once installed.
@narp914
bdstone914
Sep 18 2021, 12:21 PM
QUOTE(JamesJ @ Sep 17 2021, 07:38 PM)
Hello All,
Thanks,
James
Click to view attachment Click to view attachment @jamesj My guess is that the hole located and held the part to form the ends while manufactured. Or speed holes
Geezer914
Sep 18 2021, 02:16 PM
Lightning holes to save weight.
wonkipop
Sep 19 2021, 05:15 AM
QUOTE(bdstone914 @ Sep 18 2021, 12:18 PM)
@narp914yeah the nut is brilliantly positioned isn't it?
great if you have a vw.
JamesJ
Sep 20 2021, 05:47 PM
Thanks everyone. The PET shows a #2 for the 1.7/2.0 and a #2a for the 1.8, but no further explanation. I am curious if anyone has a 1.8 car with an original bracket without holes.
jcd914
Sep 21 2021, 12:57 AM
I have seen the fan housing coil brackets on buses, type 4s and 914s, never seen one without the extra holes.
Jim
rgolia
Sep 21 2021, 06:16 AM
Does anyone have one of those brackets they would like to sell?
@bdstone914
NARP74
Sep 21 2021, 11:22 AM
It's weight savings to keep the 50/50 distribution correct!
bdstone914
Sep 21 2021, 01:30 PM
QUOTE(rgolia @ Sep 21 2021, 05:16 AM)
@bdstone914 @Rgolia I probably do.
Or you can reshape your tin mounted to fit on the shroud.
NARP74
Sep 21 2021, 01:33 PM
If he does not, try the samba, do a search or a local VW place that has lots of parts stored away. I stumbled onto a place like that and had one moments after I asked.
rgolia
Sep 21 2021, 01:40 PM
@bdstone914 I will take it if you do. I modified the one I had and as jerry rigs tend to go the coil and bracket went for a ride in my engine compartment. No damage, but I was on the side of the road for a bit.
bdstone914
Sep 22 2021, 07:05 AM
QUOTE(rgolia @ Sep 21 2021, 12:40 PM)
@rgolia Measure your coil diameter. There are two sizes. Will see what i come up with.
Bruce
StarBear
Sep 22 2021, 12:45 PM
QUOTE(JamesJ @ Sep 20 2021, 07:47 PM)
Yep. Have an original 1.8 with original bracket and coil. The two holes are there. Never noticed them before....
