As part of my restoration I built new Center Console Wire Harnesses for both of my cars. I also ordered extra parts, so I built an additional 2 harnesses out of the spare parts.
The wires in these are color code correct ( although the brown wire available today is much darker than the original Porsche brown) All of the connectors are correct and the spade connectors that connect directly to the guages are double heat shrink wrapped to help strengthen them as well as providing an extra measure of protection from shorting against things they should not contact...
If you want to see the process I used in building them, you can see that process by accessing my build "first of the Texas Twins.
I am asking $80.00 for each plus shipping.
Thanks
