Full Version: Girl Friends Revenge Richmond VA
Pages: 1, 2, 3, 4
HFC3
I had trouble starting my restoration of a 73 914 on 914 World so I placed it on TheSamba.
I will add some background and progress as I move along.
https://www.thesamba.com/vw/forum/viewtopic...0409d5dd12e3cbd
HFC3
Looks like it’s gonna take me some time to figure out how to post pictures that are under the data restrictions
HFC3
1st day of ownership.Click to view attachment
HFC3
HFC3
HFC3
rick 918-S
welcome.png sawzall-smiley.gif smash.gif welder.gif Email them to yourself then use paint brush to resize them.
HFC3
This 914 sat in the ownership of two gentlemen in the District of Columbia.
It was kept most of his life in parking garages. I think it had a fairly easy life until a girlfriend got upset, went into the trunk and pulled out a 9 iron iron and proceeded to break out the windshield, the rear glass and both the passenger and driver’s windows.
Then she beat the car with the club and tore up most of the chrome.
She put a couple of nice dents in the car and then scratched the 914.
So now I’m gonna try and do a little bit of a sympathetic restoration and get it back on the road!
pfreiburger
OK, so she may not be marrying material...
Love the blue, it's worth the effort. Good luck with restoration!
davep
QUOTE(HFC3 @ Feb 12 2026, 09:25 PM) *
Use IRFANVIEW to manipulate pictures, best image software I have used, and have used it for decades. Crop, resize, merge, color shift, change file types; very easy.
HFC3
I first repaired both Jack points.
HFC3
More detailed pictures on the link in my first post.Click to view attachment
HFC3
The engine and transmission are ready to fall out. I need another set of eyes as I’m gonna use the forks on my tractor to finish pulling the motor.
HFC3
Pulled the motor.
HFC3
I mean, I literally pulled the motor.Click to view attachment
Front yard mechanic
Cinder blocks are …well cinder
QUOTE(Front yard mechanic @ Feb 18 2026, 07:20 AM) *
Extremely dangerous ...
HFC3
QUOTE(SirAndy @ Feb 18 2026, 02:44 PM) *
Blocks were a second backup. Metal stands on both sides.
Root_Werks
Like the color and seems like it's worth saving for sure.
brant
QUOTE(SirAndy @ Feb 18 2026, 12:44 PM) *
HFC3
Hell Hole is pretty good.
HFC3
I think I am very close to being done with Welding other than one more AC line hose in the passenger wheel well.
HFC3
Working on the engine bay.Click to view attachment
HFC3
HFC3
HFC3
HFC3
HFC3
HFC3
Jamie
QUOTE(HFC3 @ Mar 19 2026, 07:44 AM) *
HFC3
Complete blasphemy.Click to view attachment
HFC3
QUOTE(Jamie @ Mar 19 2026, 01:38 PM) *
Good idea.
HFC3
Clear coat on sides.
HFC3
HFC3
Waiting on Gumballs.
DRPHIL914
QUOTE(HFC3 @ Feb 22 2026, 09:15 PM) *
hey good work fast work , wow, but i have a question and concern,
you said the hell hole here is good, you have applied a lot of new seam sealer , what i cant see is if the stock drain hole is still there ? maybe its just the angle of the picture but i hope its not been closed off or eliminated it does serve a purpose to let water that getsinto the engine compartment a place to drain out.
Just wondering...... keep up the great work,
- ps the girlfriend story is crazy!! poor car took the brunt of the punishment!!
HFC3
QUOTE(DRPHIL914 @ Mar 23 2026, 06:33 PM) *
Good eye. I did eliminate the drain hole on that side. I was looking for a rubber drain similar to the one used in the frunk. In the end I fabricated a piece to cover the entire area with a slope to drain. Obviously not original but you really cannot see it from above.
HFC3
This is the only panel I didn’t weld. I figured it was not structural and if needed I can easily access it. The link at the bottom is a more detailed account of this build.
HFC3
I was asked why the paint?
If you inspect the pictures, you can see the scratches she inflicted. This was true on 90% of the 914.
The paint back when it had a respray was OK. Lots of orange peal etc... The body was straight at that point.
The girlfriend beat the chrome trim and knocked out all the glass F R and Sides.
Any surface rust and scratches were the result of her vandalism.
The only panel I could not save was the rear trunk lid. So a good guy (Sam) in NC gave me one that he was replacing with fiberglass. It was Yellow and had to be changed to blue.
All the panels had some some degree of scratches or dents.
My painter is like all shops, he is tied up with claim work. He likes old cars but they take up any of his free time. I was looking at 4 months just for some minor body work. A spray with body work would probably be 4500 to 6000. This was not in my budget. Down the road if I want to paint it, it should be an easy deal.
I have other two other projects that are painted and one that was just finished. Paint and body work money were tapped out. I am a car hoarder.
So my paint is an illusion. I have covered up all her scratches, fixed any dents, cut out the rust on both front fender corners and the sail panel where I found rust under the black vinyl. The car is structurally perfect now. Suspension parts are in. Rubber parts have arrived. Dash is completed. Frunk, Trunk and Gas tank area are completed.
Gas line is going to be be finished this week.
Calipers F/R are rebuilt.
Struts and Shocks are in.
Trailing arms are next.
Front bushings are on order.
Engine is out. I am sorting out what to do there. I maybe sending the heads off. Progress is good on this car. I am still below 10K at this point.
Add another 4(?) and I think I am in great shape with a rust free!!! Not less rust East Coast 914.
https://www.thesamba.com/vw/forum/viewtopic...asc&start=0
This shows more detailed pictures of the rust issues I found in a RUST Free Car. You know the deal.
HFC3
I ran a new fuel line front to rear. Installed the wind deflectors on the pan.
I was able also finish one of the vent window rubber triangles. New hoses both sides from the longitudinals to the air box. Replaced the rubber targa top holders in the trunk.
HFC3
Vent window rubber. Window wipe/fuzzies/cat whiskers etc
HFC3
Working on the rear bumper.
HFC3
Gumballs finally arrived.Click to view attachment
HFC3
SS threaded rod came in. It was so easy to hang the bumpers.
HFC3
HFC3
Fabricated chassis stiffeners Click to view attachment
HFC3
HFC3
HFC3
Final tubes to wheel wells. Everything is loose and can come in and out that way I can weld it up outside of the car with the exception of the telescoping tubes.Click to view attachment
HFC3
Tacked in place.
