Full Version: Am I running lean?
DavidSweden
Hello,
Could do with some advice from the D-Jet experts.
I’ve fitted AA big-bore cylinders and pistons to my 2.0 914. It’s still running D-Jet and actually runs really well, but I’m worried it might be running a bit lean with the extra capacity.
I’ve fitted a wideband lambda sensor, so what sort of readings should I be seeing at idle, normal cruise and under full load?
I haven’t touched the fuel pressure since fitting the big-bore kit. Should I increase it, and if so, what pressure should I be aiming for?
Thanks in advance
emerygt350
Do you have a head temp gauge installed? That is really what you want to watch to determine if you are hurting anything (well that and pinging).
I run 13.7 ish at idle (hot). At WOT I strive for 12.5 and no leaner than 13 but that is really tough and you need to learn how that changes with rpm and what is possible for your engine.
At cruise I have vacuum advance and run 16+:1 at 39 degrees advance. That is 70 mph, 3200 rpm. At cruise in most situations under that speed it is between 15 and 16 with the same advance or a little under depending on gear. Head temp at 70 under those conditions stays around 350 on the flats. This is a 2056 with 8.8ish:1 compression. Djet
VaccaRabite
You are now a custom engine owner. Congrats! Now get a good, temp compensated CHT gauge. Put the lead under the spark plug on cyl.3 - the hottest point on the engine under normal circumstances. You will need to file a small groove for the wire in the head, its not a big deal.
I'm unsure what "big bore" means to you - probably a 2056 if you were starting with a 2.0. USUALLY you need to adjust the MPS for the slight bump in displacement. There are many guides here on World about it.
But I'm way more concerned about CHTs then what my wideband says. And you will adjust both by tuning the MPS.
Zach
DavidSweden
Thanks for the feedback,
Yes, it's a 2056. I guess the engine needs to come out to install the temperature gauge?
The idea of adjusting the MPS sounds a bit risky. I had it rebuilt by Jeff Bowlsby (before installing the larger cylinders), so I'd rather not start messing around with it.
I take it that simply increasing the fuel pressure isn't the way to go?
emerygt350
I think adding pressure is better than nothing (and a good tool for troubleshooting because you can easily put it back to stock) but a cht is really what you want before you start doing anything at all. There may be nothing wrong at all with your current setup. No reason to drop the motor. You don't have to grind a channel or anything like that unless you want to. It just makes putting the spark plug in easier. I have not bothered with that. Just be good about getting it aligned with the plug so you can tighten the plug appropriately. Any kind of gap gives low temperature readings.
Although jeff can set the mps to what it was when he got it or to an approximation that is likely good enough, a push to 2056 likely needs tuning. Again, you won't know without the cht gauge.
And don't fear the mps. I tweaked mine all the time as I was working on my 2056 and with a 30 dollar tool off of Amazon you can return it to where you started if you get lost. Really there are only two adjustments you ever mess with. One plug that sets how rich it gets at WOT and another screw that increases or decreases richness across the range. It really is not rocket science.
FlacaProductions
@emerygt350 - what's the $30 tool?!
emerygt350
QUOTE(FlacaProductions @ Nov 3 2026, 11:49 AM) *
https://www.amazon.com/dp/B07CYSV5LY
FlacaProductions
ah yes - LCR - I spent a lot more on my LCR but it's good to know that option is out there! and yes - that's the key to setting/re-setting the MPS.
emerygt350
QUOTE(FlacaProductions @ Nov 3 2026, 03:22 PM) *
I wouldn't try to 'set' an MPS with this one, but you can definitely see where your MPS reads currently and return it to those settings after you mess around. Whenever I pull mine I establish the existing curve on paper and then start fiddling.
Looking at the values and descriptions from pbanders about replicability among MPSs makes me think even an expensive version isn't really going to let you set it and not tune it on the car. Hard to know what the correct values are for something so analog being measured by something so affected by the tool being used. Always make sure you have a fresh battery in the LCR as well. Makes a big difference.
FlacaProductions
Great points.
Superhawk996
Going back to the original question
“I’ve fitted AA big-bore cylinders and pistons to my 2.0 914. It’s still running D-Jet and actually runs really well, but I’m worried it might be running a bit lean with the extra capacity”
Everyone seems to have gone in the weeds about wideband O2 sensors, MPS tuning, LCR meters, cylinder head temp gauges, etc. These are all well and good and technology has its place. It does sometimes make things easier or more accurate.
50 years ago when these cars were in production we would have simply asked you one question, what do your plugs look like? You can tell an awful lot just by looking at the plugs.
Just an option and food for thought.
mgphoto
Old school check, run the engine at top speed for a minute, throw the clutch, turn the engine off, coast to a stop, pull the plugs, tan color means running great, white is hot, lean, black is rich.
emerygt350
I would say that works well but the more I poke at this in mine with modern gas and ignition (at least in my car) I am a little less confident in reading spark plugs. Within a decent range I really don't see much effect on the plugs. I have an interstate near my town with several convenient off ramps with commuter lots so I can do the full throttle engine off tests pretty easily as well as cruise tests. I have heard wiser people than I say the ethanol gas and modern additives reduce the effectiveness of plug gazing. Of course, if it is pig rich or pinging you will see that.
With the djet system I think you really do need to use gauges since you can be perfectly fine at WOT but lean as hell when cruising or just a range between something like 7 and 10inhg when at mid rpms.
The curve isn't linear and the way the full throttle stop works means you can have very different behaviors depending on load and rpm.
