JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I was going through my stuff this morning and I found a new fuel pump someone gave me a long time ago. I went online to try to find what it fits but the pump has no markings except for the name "Pierburg."
Are there any Pierburg experts out there that might point me in the right direction? Pictures attached. Thank you in advance. Terry Attached image(s) ![]() ![]() ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
A rotary pump for carbs? What's the mod #?
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Pierburg makes a wide range of pumps in different pressure and volume specifications. Might wanna slip off the insulation and see if there are any identifying marks on the body of the pump.
The Cap'n |
JawjaPorsche |
Hi Cap'n
You are much smarter than me! Why didn't I think of that! I removed the insulation and there is markings on the pump! 99T183 and 7.21565.00 Does anyone know what these markings mean? Thank you in advance. Terry Pierburg makes a wide range of pumps in different pressure and volume specifications. Might wanna slip off the insulation and see if there are any identifying marks on the body of the pump. The Cap'n |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
It's a "universal fit" pump, but the pressure output is suited to /6 CIS systems.
SPECS: EXTERNAL FUEL PUMP 150 LPH @ 5BAR INLET CONNECTION 15mm(1/2) OUTLET CONNECTION M12X1.5 LENGTH: 200 mm DIAMETER: 42 mm or 60 mm (with rubber sleeve) MAX POWER/Cons(Amps): 10 CROSS REF: BOSCH: #0580464070, #0580464008, #058046491 All you need to add is the check valve fitting at the outlet end. |
JawjaPorsche |
Wow, thanks Slits.
You really know your fuel pumps! Thank you so much. Terry It's a "universal fit" pump, but the pressure output is suited to /6 CIS systems. SPECS: EXTERNAL FUEL PUMP 150 LPH @ 5BAR INLET CONNECTION 15mm(1/2) OUTLET CONNECTION M12X1.5 LENGTH: 200 mm DIAMETER: 42 mm or 60 mm (with rubber sleeve) MAX POWER/Cons(Amps): 10 CROSS REF: BOSCH: #0580464070, #0580464008, #058046491 All you need to add is the check valve fitting at the outlet end. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Specs are straight out of an e-bay ad that comes up on a google search for "Pierburg 7.21565.00"
google is your friend |
bandjoey |
CAn someone translate 150 LPH @ 5BAR
into normal language...like FI needs 30 pounds of pressure for example??? |
Cap'n Krusty |
One BAR equals 14.5 PSI, more or less. 5 BAR is about 72.5PSI. Again, Google is your friend. CIS FI (K-jetronic) runs at that kind of pressure.
The Cap'n |
Lo-Fi Version | Time is now: 24th June 2024 - 06:02 AM |
