EdArango |
914 Enthusiast ![]() ![]() Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California ![]() |
Hi All,
Well, I've got a 1986 911sc front suspension that I want to bolt onto my 914 but wa would like to replace the rotors. I can't even get pass the center cap !!! Does anyone have any suggestion on removing this cap?? Thanks ED ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I'm doing the same thing. I just popped both caps off with a little prybar under the edge of the cap. Tap-tap on one side, tap-tap on the other and they popped off.
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Some people use a hose clamp and pry it against that others use a pipe wrench.
mikea100 |
Member ![]() ![]() Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States ![]() |
+1 on little prybar & tap-tap. Sometimes I use screwdriver. I've done it on 944 many times, same set up.
I'm doing the same thing. I just popped both caps off with a little prybar under the edge of the cap. Tap-tap on one side, tap-tap on the other and they popped off. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Big ass pair of channel locks ....
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,704 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Does anyone have any suggestion on removing this cap?? Rubber mallet. Tap on opposite sides until it comes off. (IMG:style_emoticons/default/smash.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Does anyone have any suggestion on removing this cap?? Rubber mallet. Tap on opposite sides until it comes off. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/agree.gif) |
913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
Buy this clamp from local auto parts store, should buck or two. Clamp it on the dust cap then you have something to use your pry bar against, work it evenly on it one side then the other. Thats what I use. I cant take credit. I read it on the pelican board.
Good Luck ![]() |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I copy alot of stuff from here to dorkiphus, now here's one from dorkiphus to here
Here's a quick and dirty how-to for building a replica of the Porsche factory tool for removing the bearing dust caps on the front of a 911. The inspiration for this came from helping Matt DeMaria of Stuttgart Performance Engineering tech my car for a DE one weekend. Matt said my front bearings were loose, and told me to remove the dust cover and tighten them up. So I asked him "You got a big ol' chisel I can use ta take the dust cap off?". Matt looked at me like I was insane, and then proceeded to explain to me that pounding the dust cap off with a chisel like a ham fisted gorilla eggs out the hub, which is made of aluminum. Do it too much, the dust cap won't seat anymore and you have to buy new hubs. "Fair enough. So how do you remove them?" I asked. "With this - the factory tool made specifically for this job" he said. (BTW, this is how Matt does everything - the right way, with the right tool. Its pretty impressive to watch him work on stuff, IMO). Turns out, the the factory tool is a pretty simple contraption - a metal cap with 3 set screws attached to a slide hammer. The cap goes over the dust cap, and the set screws are tighened into the groove around the cap. One good whack with the hammer and you're done - cap off with no side load to egg out the hub. Here's a picture: ![]() Anyone who knows me knows I'm a tool junkie, so I wanted one of these (since I do a lot of bearing adjusting). Matt told me that he remembers the puller running about $100 20 years ago . Looking at it, I figured I could build a replica for less. One trip to Home Depot later, I had about $5 worth of parts and was ready to go. Step 1. Get your materials. Here's what you need: (1) 2" cast iron pipe cap. (3) #10-24 x 1" Thumbscrews (1) #10-24 tap and drill bit set (1) Bolt (M6 x 25mm in my case) to attach the tool to your slide hammer (1) Slide hammer. Mine is a $10, 10lb POS from Harbor Freight. One of the best $10 I've ever spent on a tool. ![]() This is the key to the whole tool - the 2" cast iron pipe cap. $3 at Home Depot, IIRC. ![]() Step 2. Drill a hole in the center of the top of the pipe cap for the slide hammer mounting bolt. ![]() Step 3. Mark around the edges of the cap at 120 degree angles. You can see the template I used in the picture above. This doesn't need to be super precise, obviously. Step 4. Center punch at the 120 degree marks 8.5mm (0.330") from the edge of the cap. Drill with a #25 drill bit. ![]() Step 5. Tap the holes with the #10-24 tap. I bought a cheap drill and tap set from Home Depot for #10-24, came with the right drill bit for the tap. Remember to use a lubricant when tapping the hole (always a good idea ). This cap is cast iron, which is soft and taps very easily. ![]() Mmmm... threads... ![]() Step 6. With all three holes along the edge drilled and tapped, install the thumbscrews and the slide hammer attachment screw. ![]() Here's a shot from the bottom, showing how the thumbscrews will grab into the dust cap groove: ![]() Step 7. Attach to the slide hammer... ![]() And you're done! Total time to build, about 30mins. Now to use, put the tool over the dust cap and tighten the thumbscrews into the groove: One good whack and presto: |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
I copy alot of stuff from here to dorkiphus, now here's one from dorkiphus to here http://dorkiphus.net/porsche/showthread.ph...hlight=dust+cap I'm not member of dorkiphus , I can't see the pics of the goodies ....... Jack |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Most of you seem to be missing the fact that 911 dust caps (AKA grease caps) have a lip meant to be used for prying them off. Guess you spoke before you looked, huh? Happens a lot here .....................
The Cap'n |
EdArango |
These are all great replies! Thanks everyone. I'm going to try the pipe cover and slide hammer technique this weekend!
Thanks everyone! ED |
SirAndy |
Most of you seem to be missing the fact that 911 dust caps (AKA grease caps) have a lip meant to be used for prying them off. Guess you spoke before you looked, huh? Happens a lot here ..................... And that lip happens to be a perfect spot for a quick whack with a rubber mallet ... (IMG:style_emoticons/default/shades.gif) |
bcheney |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States ![]() |
I have used "PB Blaster" penetrant in the past to help loosen things up a bit. You can pick up a can at most any auto parts store department.
Lo-Fi Version | Time is now: 25th June 2024 - 12:23 AM |
