914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,196 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
This will ultimatly house the Yellow 73.
Anyone have have any experiance in creating a "Dry" Carport? Im looking for solutions. (IMG:style_emoticons/default/wink.gif) Attached image(s) ![]() |
914werke |
another
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
First you put a roof on, then walls. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif)
Looks good, the pitch of the roof is gonna dictate the types of roofing you can use. You're gonna need a fair flashing where you tie into the house. I suppose all of that is already figured especially if you got permits. Maybe Geoff will give you some advice. Dave |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Why not just close it in?
If your after the "open look" you could make removable panels for the winter months. |
914werke |
Nah. I may put up some lattice between the post to pretty it up, but Im just concerned with the drip through from the top.
Dave, Permits? Whats a permit (IMG:style_emoticons/default/laugh.gif) One of the benifits of living in the woods is no one is in your business. I talked to the county about code requirements while designing it. First Deck, by myself. (IMG:style_emoticons/default/rolleyes.gif) Pretty good sofar. (IMG:style_emoticons/default/beer.gif) |
SpecialK |
aircraft surgeon ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 ![]() ![]() |
Oh, I see...it's a deck! I was thinking it was strictly a carport until your last post. Check out this site:
http://www.dry-b-lo.com/ |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,709 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
that looks nice!
suggestion: while you're at it, build a pit in the center so you can work under the car easier! (IMG:style_emoticons/default/biggrin.gif) Andy |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
QUOTE(SirAndy @ Sep 12 2004, 12:33 PM) that looks nice! suggestion: while you're at it, build a pit in the center so you can work under the car easier! (IMG:style_emoticons/default/biggrin.gif) Andy thats what i'm a do when i design my house (IMG:style_emoticons/default/wink.gif) |
914werke |
A pit was out of the question...BUT it has near 10Ft of ht. between slab & Joists, so Im think'n ...LIFT! (IMG:style_emoticons/default/smilie_pokal.gif)
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Permits are for the people who don't do he work them selves. Because there has been a few shady contractors who take your money because you don't know any better about what right / wrong and "up to code".
So the public invented building inspectors. = retired contractors. I built a shop on the back on my house bricked the outside to match the existing house. hurricane straps and big long screws lots of nails and wood vapor barriers and insulation. wall outlets and overhead lighting. Should be tested against a CAT 4 Hurricane this week. If it stands up I will thump my chest. If it blows down I will build it bigger and stronger. |
Carl |
Ummm ... what? ![]() ![]() ![]() Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California ![]() |
VLPC?
LLIHALPCTM!* * Looks like it'll have a lotta Porsche content to me! (IMG:style_emoticons/default/clap56.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
rich, it will involve some more framing, but you might/should be able to add a secondary roof under the deck joists. sheath it and use rolled roofing. you can get away with a low pitch. if you wait to apply the decking, tuck the flashing under the bottom of a course of siding and you can nail the plywood and the rr down.
kevin |
914werke |
So I realized that I had never posted completed pics of this project and how its going to good use! (IMG:style_emoticons/default/biggrin.gif)
What ever happened to the idea for a jackstand smilie. (IMG:style_emoticons/default/happy11.gif) |
rhodyguy |
what did you do to keep it dry underneath?
k |
914werke |
914werke |
914werke |
rhodyguy |
i can't tell what that is. did you just staple some plastic to the bottom of the joists?
k |
914werke |
i can't tell what that is. did you just staple some plastic to the bottom of the joists? k No I furred down from the joists, used this polycarbonate roofing and while angling from rear to front and from center to side screwwed it to the the furring with these rubber washered screws. You can sort of see on the inside of the beam is a 1" U channel I used as a gutter angled the same center out to side. |
rhodyguy |
oh, green house roofing. good choise. fire up the enigne yet?
k |
Lo-Fi Version | Time is now: 27th June 2024 - 06:09 AM |
