> tail lights not on with headlights
jdlmodelt
post Jan 6 2013, 05:01 PM
James D. Lane
Okay. I am working my way thru all the electrical connections putting this 72 back together. I have the signal lights, headlights, brake lights working but I can't get the tail lights to go on with the head lights. I have two remaining wires on each tail light that I have not connected. one is the backup lights the other the markers for night time. I have not be able to get either of the two working yet. The front marker lights work when the head lights are on. Is there a common place to look for discontinuity for the rear tail lights?
I took her out for a short 1 mile drive. barely got into 4th gear. she is really spunky. I like the power. My county roads are still iced up and I can't really put my foot in it yet.
J
Tom
post Jan 6 2013, 05:13 PM
Fuse #9, 8 amp. Check for good fuse and good connection.
Tom
jdlmodelt
post Jan 6 2013, 06:10 PM
James D. Lane
QUOTE(Tom @ Jan 6 2013, 04:13 PM) *
Tom
which fuse is fuse 8? I haven't found a fuse guide in the Haynes manual?
Here's a pic of the teener in daylight!Attached Image
JawjaPorsche
post Jan 6 2013, 06:33 PM
Pull fuse box cover and look to see if any fuses are broken or not seated correctly. If the cover is missing, it is extremely easy to dislodge them when you get in and out.
jdlmodelt
post Jan 6 2013, 06:49 PM
James D. Lane
QUOTE(JawjaPorsche @ Jan 6 2013, 05:33 PM) *
Haha! I don't have a fuse cover! I'll look closer to see if I have a burned fuse. I don't see any loose wires under there either?
steuspeed
post Jan 6 2013, 06:51 PM
Look in your cars glove box manual.
Or here:
http://www.pelicanparts.com/914/technical_...rical_fuses.htm
Pictograms are on the clear fuse box cover which is usually lost/broken.
jdlmodelt
post Jan 7 2013, 07:34 AM
James D. Lane
QUOTE(steuspeed @ Jan 6 2013, 05:51 PM) *
Or here:
Do the tail lights tie in with a spade connector somewhere with the front marker lights? If so...where could I look for that? I hope not up under the tiny little dashboard. (IMG:style_emoticons/default/headbang.gif)
jbyron
post Jan 8 2013, 11:28 AM
Jamie
Since #9 also includes cigarette lighter, perhaps check to see if you're getting power there?
- Lo-Fi Version Time is now: 31st October 2024 - 08:23 PM
