Tunnel rust, Help |
Tunnel rust, Help |
spunone |
Jan 12 2005, 09:28 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
After removing inspection plate I've found some surface rust inside tunnel now what.How do I clean this up or should I just put cover back on and act like I never saw it or do I get out the saw? (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif)
Joe Ricard |
Jan 12 2005, 09:53 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
The DAPO of the stripper had cut most of the top section of the tunnel out. actually cut through the Clutch cable housing.
Guess he was overwhelmed by the amount of scaling rust he found so he built a plywood cover though some carpet over it and put the car up for sale. Don't be a DAPO!!!! So What I am going to do is continue cutting and then replace what ever is required. I like to fix it right once. (mostly) (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
spunone |
Jan 12 2005, 09:57 AM
Can I just cut off top of tunnel sand blast POR15 and make a larger inspection plate or reweld top back on?What has everybody else done I know I can't be the first with this problem or can I?/ (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
IronHillRestorations |
Jan 12 2005, 10:18 AM
I. I. R. C. Group: Members Posts: 6,762 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
OK, my secret technique revealed! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
What we do in my restoration shop is clean, treat/arrest the corrosion, repair any corrosion that involves very heavy pitting or perforation, treat with phosphoric acid wash, rinse, dry, and paint. We use a undercoating kit that can be purchased at JC Whitney, Eastwood, and other auto supply houses. We treat the entire car, that is all the dead air spaces, boxed support members, etc. First remove the control cables, and shift mechanism, as well as the pedal cluster, and most of the interior. Mask off the wiring harness with plastic and masking tape. Clean out the tunnel with compressed air and a shop vac. Manually scrape whatever you can reach with wire brushes, stainless toothbrushes, etc. Next you need very hot water and cheap automatic dishwashing detergent (like cascade). You don't want to get this on finished surfaces, as the trisoduim phosphate can dull painted surfaces. Mix up hot water with the detergent, and spray in into the tunnel. With the undercoating kit you get spray wands and different nozzles to blast in the corners, etc. Again, use the shop vac to remove the water. Next rinse with clean warm water, and clean this up. Blow dry with compressed air and the undercoating wands and nozzles. Check out the cleaning job with a light and a inspection mirror, make sure everything is nice and clean. Let it dry for a few days. At this point a little flash rust isn't going to hurt anything. Now it gets more fun! You can use Ospho, Oxysolve, any corrosion treatment with phosphoric acid that leaves a phosphate coating. You mix up the acid as directed, and after you've donned your safety goggles, respirator, and rubber gloves, you spray the area with the acid mixture. Most of them require liberal dousing, and you want to keep it wet for several minutes, longer if you've got more serious corrosion. Next you rinse the acid off with water, and clean it up. Blow it dry. Let it sit for a few days. Last you can use the same undercoating kit to blast your favorite corrosion paint over the treated areas. This is alot of work, and makes a big mess, but it's the best thing you can do to mitigate corrosion. It's also a good thing to do if you've welded on structural supports like the GT stiffening kit, Mayeur kit, etc. If you don't treat the backside of a panel that you've welded, it will rust. |
spunone |
Jan 12 2005, 10:28 AM
Thanks Perry thats the info I needed very good instructions Thanks again (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
obscurity |
May 2 2006, 08:44 PM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
Lets suppose the sides of the tunnel are rusted through in places? Do you just cut the sides off and reweld on new metal or are there replacement tunnels (dare I dream)?
shoguneagle |
May 2 2006, 10:26 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Perry, how did you know I was in need of your information. Just what I wanted. To let you know, I am building my 914-6 and using Rich Johnson 's parts and advice.
Hope things are going well for you. Steve hurt |
Lo-Fi Version | Time is now: 28th September 2024 - 12:18 PM |
