Paint prep under the headlights? |
john77 |
Dec 24 2019, 02:58 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I have a feeling I'm not the first to ask this, but I did a search and couldn't find an answer.
My front trunk needs some love. I've stripped and painted a couple of 2002 engine bays, so I know what's involved when it comes to prep, but I'm a little confused by how to deal with the void under the headlight buckets? There's barely enough room to squeeze my hand in there no matter any tools. Is there a secret to prepping and painting that area? |
burton73 |
Dec 24 2019, 03:44 PM
burton73 Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have a feeling I'm not the first to ask this, but I did a search and couldn't find an answer. My front trunk needs some love. I've stripped and painted a couple of 2002 engine bays, so I know what's involved when it comes to prep, but I'm a little confused by how to deal with the void under the headlight buckets? There's barely enough room to squeeze my hand in there no matter any tools. Is there a secret to prepping and painting that area? You need to remove the headlights and eyebrows. You will remove the lids on the flip up lights and prep all the area Clean out the drain and repaint. It can be dirty there as years of dirt and leaves can collect. You can buy new rubber pieces for the eyebrows. Not hard to do. Detailed info can be found on the world Bob B |
jmitro |
Dec 25 2019, 05:15 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Bob B you got to learn how to put your comments outside the quotation marks (IMG:style_emoticons/default/shades.gif)
John77 are you referring to A or B? If B, I used Eastwoods internal frame coating on a spray wand to rust proof it, then sprayed with the paint gun the best i could |
Lo-Fi Version | Time is now: 25th June 2024 - 07:50 PM |
