MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
Hi all...does anyone have any photos of an AFR sensor installed on a 2.0 liter with factory heat exchangers and muffler?
Thanks!! |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Hi all...does anyone have any photos of an AFR sensor installed on a 2.0 liter with factory heat exchangers and muffler? Thanks!! This is where I mounted mine. The most ideal is one on each side, close as possible to the heads to get the most accurate mixture. (IMG:http://live.staticflickr.com/4345/37253366491_cf0aa6ce7e_c.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1594222962.1.jpg) |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
That’s pretty much the same place that I mounted mine. Seems to work fine (IMG:style_emoticons/default/beerchug.gif)
MikeM |
I guess that's where it will have to go...no good place before the muffler!!
Thanks |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I would have recommended the opposite side, as far away from the actual tailpipe that you can get, especially if you are trying to do any tuning with it. What I have seen with the sensor close to the tip like that is fresh air makes its way back in the tailpipe at idle/lower speeds providing invalid readings.
Stock style mufflers are really not ideal for getting good readings from a wideband. If you are doing actual tuning (aftermarket injection etc) rather than just installing a gauge I would recommend picking up a used Bursch or something else with a collector before the muffler to use while turning and then swap back to your stock exhaust when done. |
Frank S |
Member ![]() ![]() Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany ![]() ![]() |
[quote name='JamesM' date='Jul 9 2020, 12:53 AM' post='2832142']
I would have recommended the opposite side, as far away from the actual tailpipe that you can get, especially if you are trying to do any tuning with it. What I have seen with the sensor close to the tip like that is fresh air makes its way back in the tailpipe at idle/lower speeds providing invalid readings. Stock style mufflers are really not ideal for getting good readings from a wideband. If you are doing actual tuning (aftermarket injection etc) rather than just installing a gauge I would recommend picking up a used Bursch or something else with a collector before the muffler to use while turning and then swap back to your stock exhaust when done. I would 100% agree with the above. BR Frank |
Lo-Fi Version | Time is now: 26th June 2024 - 05:56 AM |
