watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I'm going to install the foam and vinyl on the top of the dash, between the dash top and the windshield. I've read several of the previous posts, with several recommendations of using 1/8" foam. Should I cut the foam to the exact dimension of the dash or should I trim it 1/4"? I understand that I'm suppose to glue the foam down, and only glue the edges of the vinyl to the metal frame, not to the foam.
Any other suggestions? -- Rob |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I'm going to be doing this as well. (IMG:style_emoticons/default/smile.gif) |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
YMMV but I glued my dash top material straight to the metal.
Sad to say, but I think it will actually last longer than the rest of the car... |
davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
I'm going to install the foam and vinyl on the top of the dash, between the dash top and the windshield. I've read several of the previous posts, with several recommendations of using 1/8" foam. Should I cut the foam to the exact dimension of the dash or should I trim it 1/4"? I understand that I'm suppose to glue the foam down, and only glue the edges of the vinyl to the metal frame, not to the foam. Any other suggestions? -- Rob Get 1/8" CLOSED-CELL foam. Not the standard open-cell stuff. Open-cell foam will absorb the spray adhesive into its pores and will completely and permanently collapse. Sorta like not having foam at all. Cut the foam to exactly the size of the dash. I used some sandpaper to round the edges of the foam -- adding a subtle little fillet prevents a sharp cut edge from showing through the vinyl on top. Cut the vinyl slightly oversize. I can't comment on your edge-gluing process. I glued the entire surface of the foam and struggled to get the vinyl stretched and stuck down evenly. Maybe gluing only the edges would make it easier? |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
I glued a large piece of foam on and trimed it at a slight angle with a single edge razor along the edges. Then glued the vinyl on.
![]() Attached image(s) ![]() |
watsonrx13 |
Thanks for the responses and the pics....
Now, is the dash/windshield rubber seal still available, if not, what is the alternative? -- Rob |
PRS914-6 |
NLA. AA or others has a substitute....
Brando |
Contact Glenn at Pelican Parts for a "replacement" dash top seal. Turns out one of his door seals snugly fits right in (and looks good too).
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
I'm going to install the foam and vinyl on the top of the dash, between the dash top and the windshield. I've read several of the previous posts, with several recommendations of using 1/8" foam. Should I cut the foam to the exact dimension of the dash or should I trim it 1/4"? I understand that I'm suppose to glue the foam down, and only glue the edges of the vinyl to the metal frame, not to the foam. Any other suggestions? -- Rob Autos International has the foam & Vinyl. Ken |
watsonrx13 |
Besides ordering the closed cell foam, is there any generic store I could get it locally from, ie. Walmart, Lowes, etc?
-- Rob |
dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
I got mine from
Sunshine Foam Cincinnati Ohio 513 681-7300 I bought a roll and used it under my headliner too. They mailed it and it wasnt very expensive. I still have lots left. Can sell you enough to do the dash top if thats all you need. Send me an IM or call Sunshine Foam. |
tyler |
Member ![]() ![]() Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 ![]() |
It's available but I bought one of the cheap ones and it wouldn't lay down and fit right so I returned it. I bought the good one which was about $100 and it fits great. I have an extra one (I think it's a good one) I'll give you a deal on if you're interested.
I put the vinyl on and left the old foam and just glued the edges of the new vinyl after templating it from the old piece. It would have been better to put new foam on in the exact same places as stock. One thing to watch out for is where the vinyl goes under the dash cover in back of the instruments. If there's not enough foam there it will leave a gap because the vinyl will lay too flat. So I think it's very important to place the dash onto the vinyl for a test fit when you're installing the vinyl or you could be in for a surprise later on (happened to me) when you re-install the dash. Now, is the dash/windshield rubber seal still available, if not, what is the alternative? -- Rob [/quote] |
HeavyHeavy |
Member ![]() ![]() Group: Members Posts: 62 Joined: 7-June 06 From: Albuquerque Member No.: 6,177 ![]() |
I covered mine too. It didn't seem to matter that much about leaving the foam piece bigger. I made a template with paper first and cut it out to be as close to exact as possible. It would have been nice to have the whole dash out, but I was able to do it with just the windshield out. I used some super strong spray adhesive to hold everything down and I sprayed it on the entire surface - not just the perimeter. It seems pretty good and it's been in the sun and in the cold.
I used some left over foam and vinyl to cover a console that I made, so that matches too. I got my supplies here: http://www.newmexicofabricsandfoam.com/ |
watsonrx13 |
I ordered the foam from the Foam Factory in MI.... Expect to receive it later this week...
-- Rob |
tyler |
I found the one I have it's brand new. The original has metal in it but this one is all rubber. If anyone wants it let me know. I'll try to find the receipt and send you a pic and a copy of the receipt for a deal.
======================= Now, is the dash/windshield rubber seal still available, if not, what is the alternative? |
watsonrx13 |
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
Where did you get the vinyl?
watsonrx13 |
Then I glued the front section down. As suggested, I only glued the edges, nothing in the middle of the foam.... I used a screwdriver to push the leading edge of the vinyl down around the windshield... I used popsicle sticks to hold the edges down..
![]() I let the front section dry a little, then I glued the back section. After making certain the vinyl was completely down and smooth, I placed the dash top on it to hold everything down.... I'll check tomorrow to make sure it stays in place... ![]() -- Rob |
watsonrx13 |
Fyrmdk914 |
Newbie ![]() Group: Members Posts: 27 Joined: 12-November 06 From: San Diego Member No.: 7,203 ![]() |
Is it nescessary to remove the windshield for this operation, or can this be done with the windshield in place?
Lo-Fi Version | Time is now: 8th July 2024 - 02:31 PM |
