RonnieJ |
RonnieJ ![]() ![]() Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest ![]() |
What type of black paint is used on the 914 Fuch wheels and can you rattle can them or is it best to take them to a painter?
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
The American Eagle? fakies were painted matt black!
RonnieJ |
Thanks
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Paint was applied at the dealer level. They used rattle cans where I worked. Lot boys did 'em. The Cap'n
SLITS |
Paint was applied at the dealer level. They used rattle cans where I worked. Lot boys did 'em. The Cap'n Somehow I can't see you as a go-fer .... even at a younger age. I did Jaguars / Austin Healys (IMG:style_emoticons/default/biggrin.gif) |
Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
I know they dipped the original early 5 bolt fuchs to add the black background. When you respray the black, is there a better way then using masking tape to get a straight line?
I know they sell wheel masking kits for the MG crowd.... |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
some alternatives to drab boring ......black
Attached image(s) ![]() |
pete-stevers |
and surprised this one isn't salmon..... (IMG:style_emoticons/default/bootyshake.gif)
Jasfsmith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States ![]() ![]() |
I know they dipped the original early 5 bolt fuchs to add the black background. When you respray the black, is there a better way then using masking tape to get a straight line? I know they sell wheel masking kits for the MG crowd.... You'll chuckle at this method. A friend of mine had a set of so-so 5 bolt Fuchs with the anodizing pretty much gone. He degrreased the wheels completely, set up a flat bottom tub, placed the wheel front side up, and poured in satin black paint until it reached the correct level partially coating the pedals. Removed them carefully, placed them on a raised grille and let the paint drain and dry. Exceptional finish. No masking to deal with. Only down side I could see was the waste of paint. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:29 PM |
