jimtab |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California ![]() |
I think I want to buy my own helmet for the up coming season and beyond, it's been years since I bought one, so how about some advice from you teener floggers. What are your recommendations? Where is the best and least expensive place to buy one. Do we have sponsors who sell them? What color is fastest? Etc. Etc. Thanks in avance. Jim (IMG:style_emoticons/default/welder.gif)
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I dont think anyone close to you sells helmets. I normally send people to Frey racing or Wine county motorsports at Sears point.
Dont buy one online. You have a fat head (I can say that.. I know him personally.. dont jump my ass in PM's and emails..LOL) You need to test fit several helmets before you decide. B |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
I made mine out of tinfoil.. cuts down on the intercepted brainwaves.
(IMG:style_emoticons/default/clown.gif) M |
stock93 |
Member ![]() ![]() Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States ![]() |
What are the requirements for an auto x helmet? I'm just wondering because I plan to autox eventually myself and I always figured I could use one of my motorcycle helmets. They are dot and snell95 rated.
John |
Brad Roberts |
A lot of the AutoX orgs let you run what you want (I have seen MotoX helmets used)
I personally value my skull and dont mind spending *some* money on it with a real racing helmet. A motorcycle helmet is designed for one hit. The racing helmet is designed for multiple hits (bouncing around inside a car). B |
aufaber |
Member ![]() ![]() Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 ![]() |
You can go try them on at your local motorcycle shop to figure out your sizing. I know there is a Cyclegearin San Francisco.
The consesus on this board is to buy cheap, and I've already argued that enough. So all I'll say is, "You get what you pay for." |
Brad Roberts |
The cyclegear is one block from Andy's office (Resident German)
B |
jimtab |
QUOTE(redshift @ Dec 21 2003, 10:32 PM) I made mine out of tinfoil.. cuts down on the intercepted brainwaves. (IMG:style_emoticons/default/clown.gif) M Well, of course, I will line mine as well....you can't be too careful. |
aufaber |
SA2000 snells are tested against a roll bar anvil 3 times in the same spot for mutiple locations on the helmet and once against a sharp edged anvil, while M2000 snell's are just tested against a sharp edged anvil once for mutiple locations on the helmet.
SA2000 helmets must also be flame retardent, while M2000s don't need to be. At least make sure it is snell certified. http://www.smf.org/ |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,526 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
Check out this old helmet thread.
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
the biggest thing in buying a helmet (IMO)
1. It's SNELL certified 2. It FITS 3. You can see out of it. (there are several different eyeports available from the different manufacturers) |
redshift |
QUOTE(seanery @ Dec 22 2003, 09:41 AM) the biggest thing in buying a helmet (IMO) 1. It's SNELL certified 2. It FITS 3. You can see out of it. (there are several different eyeports available from the different manufacturers) 4. It comes in a lavender color to match my ascott (IMG:style_emoticons/default/huh.gif) M |
seanery |
lavendar isn't really my color.
Mine is more Green & Maroon. (IMG:http://www.914world.com/bbs2/uploads/post-2-1047480663.jpg) |
Don Wohlfarth |
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-January 03 From: Fairfax, VA Member No.: 117 ![]() |
This link gives a couple differences between M and SA helmets
http://www.unofficialbmw.com/all/track/all..._selection.html Find the Snell Foundation here http://www.smf.org/ IMHO I would not want to bet any money that there's any difference in the way SA and M helmets are manufactured. Main difference is the fire rating of the liner and how they are tested. If you already have a M helmet you "may" be able to use it for ax. If you have to purchase a helmet buy a SA (special applications) that you can use for both ax and track events (comes under the category, right tool for the right job). "Most" people that run track events will not accept a M helmet. You want a helmet that's snug, not tight. Put the helmet on and fasten the strap. Grab the back of the helmet and lift. If the helmet comes down over your eyes it is too large. FWIW every helmet I've ever had pinches my ears. I remove the liner and trim a very little off the foam on both sides until it's comfortable. Depending on your budget a light weight helmet can help with sore neck muscles. For track events a dog collar that fits around your neck will help with sore neck muscles and in case of a crash will cut down on the amount of movement from the helmet. |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
PCA requires a Snell 95 or greater. I have a Snell 2000 that I got at a motorcycle shop. It works great for AX, but I would not road race with it. Some tech people at AX's will check your helmet, some wont....
Lo-Fi Version | Time is now: 23rd June 2024 - 12:48 PM |
