Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
PET 501-00 #32 lock washer qty:16
lock washer used with CV bolts. this pix was copied from www.gowesty.com. commonly called a schnorr washer. another substitution: http://www.mcmaster.com/#standard-washers/=dknups 90895A030 stainless steel M8 another source: https://www.belmetric.com/metric-schnorr-wa...1l8gfe91p30l1t4 (I have seen a recommendation to NOT get the stainless washer because it's too soft http://dorkiphus.net/porsche/showthread.ph...6101&page=2 ) Attached image(s) ![]() |
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
Replacement available from McMaster-Carr
Part Number: 93501A030 Belleville Shape - Serrated Top and Bottom |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
8mm ID
These are formed with a 'cone' shape. If your old ones are flat like a 'normal' washer then they will not hold as tight. I choose to treat these as a single use item. I throw them away and use new every time. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) With McMark
Lo-Fi Version | Time is now: 25th June 2024 - 08:06 PM |
