Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
As mentioned we've been working on these for some time. Just getting to finishing these up.
They change the airflow to help cool the engine better. $28 A set who's in? |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,970 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
1 set for me.
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
<---- two pair
clapeza |
Member ![]() ![]() Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States ![]() ![]() |
I'm in for a set!
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Do these work better than the stock ones?
Mikey914 |
Do these work better than the stock ones? The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it. (IMG:style_emoticons/default/biggrin.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
In for a set, one of mine is broke halfway through.
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. Geez, how can I resist a "wingtip vortex generator?" I'm in for a set. Mark, I thought you just flew planes. I didn't think you knew anything about how they work (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
One of the few aviation geeks that decided to build car parts instead of kit planes. However, I have made some parts for some friends experimental aircraft.
So not you too can fly low and fast across the ground (IMG:style_emoticons/default/biggrin.gif) |
drem914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California ![]() ![]() |
I'm in for a set.
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,331 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
I’ll take one set, please. Another great product
Grosbard |
Member ![]() ![]() Group: Members Posts: 88 Joined: 29-September 09 From: Pasadena, CA Member No.: 10,862 Region Association: Southern California ![]() ![]() |
I'm in for a set! Great work!
aharder |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,429 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region ![]() ![]() |
I'm in for a set (IMG:style_emoticons/default/biggrin.gif)
brownaar |
Member ![]() ![]() Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None ![]() |
I'm in. Have to work better than my current ones. New is always better anyway, right?
beech4rd |
Member ![]() ![]() Group: Members Posts: 344 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States ![]() ![]() |
Put me down for a set. Thanks.
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 860 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Pictures please and is there any quantifiable evidence of cooler temperatures? Just thinking out loud here....thank you.
gg |
SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
I'd be in for 2 sets.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Yeah what do these things do? 4 or 6 cylinder?
VoPo914 |
Member ![]() ![]() Group: Members Posts: 74 Joined: 11-January 07 From: Lincoln, Nebraska Member No.: 7,449 Region Association: Northstar Region ![]() |
I'm in for a set. Thanks!
GregAmy |
Yeah what do these things do? 4 or 6 cylinder? If you look under your car, attached to the bottom of the firewall (or, well, supposed to be) are two little air deflectors that hang down. They're supposed to be hanging down from the firewall. The purpose of these are to - duh - deflect under-body air downward and create negative pressure behind them, under the cylinders. Due to this negative pressure the positive pressure at the top of the cylinders will cause air to flow faster/better downward through the cylinders and heads, improving cooling. If you don't have these, you really should. It's actually surprising how effective they are. Edit: found a photos online. It's that black deflector at the bottom of the photo: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircoolednut.com-15565-1507673728.1.jpg) |
hermich |
Newbie ![]() Group: Members Posts: 18 Joined: 22-March 10 From: Johns Island, SC Member No.: 11,492 Region Association: South East States ![]() ![]() |
I'm in for one set...thanks!
Lo-Fi Version | Time is now: 27th June 2024 - 02:18 AM |
