pvollma |
Member ![]() ![]() Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
GREAT BUY!!!! The other guys are selling theirs for $49.95.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
And mine will be better NOT a URO part
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
And mine will be better NOT a URO part Well Jeez....you better put me down for a set as well then. (IMG:style_emoticons/default/wink.gif) |
gus'914 |
Newbie ![]() Group: Members Posts: 8 Joined: 11-October 14 From: Inland Empire, So Cal Member No.: 18,007 Region Association: Southern California ![]() |
I'm in for one set...thanks!
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
In for a set
914Next |
Senior Member ![]() ![]() ![]() Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest ![]() ![]() |
Here's a pic of mine when I took them off to clean the undercoating off....before and after.
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
I don't think mine are in bad shape, but I'm in to try better ones.
Mikey914 |
Yeah what do these things do? 4 or 6 cylinder? They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member). Hope this helps with the concept and thanks for posting the pics up!. |
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
I would like a set,please
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
I'm in for a set please.
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Yeah what do these things do? 4 or 6 cylinder? They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member). Hope this helps with the concept and thanks for posting the pics up!. The amazing thing about this forum is that the answers come before I even have to ask the question. Thanks Mark! Definitely in for a set. |
NeunEinVier |
Member ![]() ![]() Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None ![]() |
And mine will be better NOT a URO part Lol, too funny. Don't believe Uro manufactures these anyhow. Interested, adding it to my lengthy "would be nice to have" list. EDIT: I stand corrected, apparently they do. http://www.914world.com/bbs2/index.php?showtopic=317435 |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
Yup (IMG:style_emoticons/default/confused24.gif) I'll take a set (IMG:style_emoticons/default/beer.gif)
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
In for a set.
11tenths |
Ve get too soon old, und too late schmart ![]() ![]() Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States ![]() ![]() |
I'll take a pair of "Wingtip vortex generators", size 11 D, in brown, please.
(IMG:style_emoticons/default/sunglasses.gif) - HB |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'll take two sets
CMONNETT |
Member ![]() ![]() Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region ![]() |
I'll take two sets.
Thanks, |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Do these work better than the stock ones? The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it. (IMG:style_emoticons/default/biggrin.gif) How many volts? (IMG:style_emoticons/default/smile.gif) Put me down for a set of "improved" upon design if make one. |
rmdinmd |
Member ![]() ![]() Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
in for a set
Lo-Fi Version | Time is now: 20th June 2024 - 06:16 AM |
