intermittent injector, #3 cyl 73 djet 1.7 |
elsargento |
Oct 11 2009, 01:02 PM
Newbie Group: Members Posts: 44 Joined: 9-September 06 From: Topanga, California Member No.: 6,802 |
Running Gumout injector cleaner thru the system. Thinking about sending all 4 to witchhunter if cleaner doesn't work. Is it just that the solenoids stick then clear then stick? When clear runs like a top.
If I send them to witchhunter do I need to buy new seals or do they come back with them included? (IMG:style_emoticons/default/welder.gif) |
type47 |
Oct 12 2009, 08:51 AM
By "seals" do you mean the mounting rubber injector seals to the intake manifolds? If so, then I doubt they come from the injector rebuilding company.
underthetire |
Oct 12 2009, 10:05 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Believe it or not, Autozone has the O-ring type seals, upper and lowers. Comes in a generic kit for about 8 bucks. Seems most injectors use one of two styles.
2-OH! |
Oct 12 2009, 06:16 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Witchhunter is a good deal...Does not come back with seals...Yes, new seals...
2-OH! |
Lo-Fi Version | Time is now: 26th December 2024 - 11:34 AM |
