Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
where does everyone relocate their pumps. i need to move it up front and have room for a swaybar. i have a good facet pump.
please esplain where it can go and be out of the way (IMG:style_emoticons/default/wink.gif) Thanks in advance |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I have only heard of this done with the stock FI pump. Maybe I have not paid enough attention though... (IMG:style_emoticons/default/unsure.gif)
Engman |
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 ![]() ![]() |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Here is the front location of a Facet pump. Eventually changed to a rotary. Needs to be mounted with rubber insulators. I used a pair of 914 fuel pump insulator rubbers.
CCLINPUMPITUP Attached image(s) ![]() |
boxstr |
I also found a fitting for the Facet to take the loop out and have it run straight back. No pic of that.
Aaron Cox |
is it even neccessary for a carbed car? i have mine up front (under gas tank) but is in the way of installing a swaybar
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
A facet should fit real nice right here (stock location for a 75/76 fuel pump) even with a bar -- note the brake lines for a reference point -- this is on the drivers side fo the car. The bar is above the hole.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Next to the spare tire is enough out of the way. There's enough room even with a stock spare held in place. The extra line is not a problem with performance, etc. While moving the pump is not necessary. I like the fact that when my lines were lose, it shot fuel out of a place I could easily get to. (IMG:style_emoticons/default/wink.gif)
boxstr |
Yes you will need to change to a different pump for carbs. I also like the pump out in tehopen, easy to get to for any replacement and fliter change.
CCLINPUMPME |
cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 ![]() |
Here is how I did mine:
(IMG:http://www.914world.com/bbs2/uploads/post-2-1070519251.jpg) Its a low psi rotary pump for my carbs. Tony |
Eddie914 |
Unregistered ![]() |
What hose are you using for your oil cooler?
Where did you get it? Thanks Eddie |
cha914 |
Eddie,
check out this thread for more info about my oil cooler setup: http://www.914world.com/bbs2/index.php?act...&f=2&t=7103&hl= The lines are made by aeroquip and use barbed fittings...I bought mine from www.racerpartswholesale.com yours, Tony |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Here's mine.
J P Stein |
We gots coolers too
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
we run two pumps, second one pulls the gas up out of the cel.
when we convert to carbs, will get rid of original FI pump. dr Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 06:14 AM |
