oil cooler out back |
machina |
Mar 16 2004, 02:20 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
I realize this is probably the tranny cooler but would this work for the primary oil cooler setup?
Anyone try it, and not by pauls method of dragging the cooler behind you. thx dr Attached image(s) |
seanery |
Mar 16 2004, 02:30 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I haven't tried it, but where is your air coming from?
You'd need a naca duct or something similar on your rear lid. |
machina |
Mar 16 2004, 02:34 PM
what about opening the back panel, like in the photo but at centerline.
get air from underneath, cut hole in trunk floor. maybe I'm barking up the wrong tree, just don't want to cut up the front trunk. looks to purty right now. dr |
seanery |
Mar 16 2004, 02:35 PM
If you cut a hole in the trunk, aren't you using pre-heated air?
that's also a low pressure area right? so, your volume will be kinda low. |
tat2dphreak |
Mar 16 2004, 02:51 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
you could use electic fans to increase the airflow, but you are still using HOT air...
Dave_Darling |
Mar 16 2004, 03:05 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
On that car, at least, it's a transmission cooler. I don't think I'd trust it as an oil cooler.
Air comes in from the engine bay, via the two circles where the latches would sit if the roof were stored in the trunk. Not a lot of flow, but some. Prolly good enough for a tranny cooler. --DD |
brant |
Mar 16 2004, 03:23 PM
914 Wizard Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don't think its a great Idea..
not enough air flow... plus you really don't want to move the weight back there.. plus its behind the wheels so thats even worse... front coolers are tried and true for oil... b |
campbellcj |
Mar 16 2004, 03:24 PM
I can't Re Member Group: Members Posts: 4,555 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
The lid for that car probably has an inlet scoop. Otherwise all you'd be doing is heating up the trunk.
SirAndy |
Mar 16 2004, 04:13 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(seanery @ Mar 16 2004, 12:30 PM) I haven't tried it, but where is your air coming from? You'd need a naca duct or something similar on your rear lid. that car actually has a duct in the rear hood that channels the air down through the cooler. and yes, this is a transmission oil cooler ... Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 03:27 AM |
