steveherman |
Member ![]() ![]() Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States ![]() |
How do you remove the knob?
i have twisted... pulled.... what am i missing? |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
unscrew counter clockwise..
steveherman |
and then what?
the knob pops off? are you talking the rotatating ring? i have been rotating and rotating that ring... |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Pull the engine lid release knob out; grab the shaft with some needle nose pliers while turning the knob counterclockwise. You have to make the shaft stationary in order to turn the knob.
If you are removing the backkpad; use the tips of the needle nose pliers to turn the plastic plate where the shaft enters. |
steveherman |
now that makes sense...
and it worked. |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
It's hard to see in the pic, but I suggest using a 911 "T" handle for the engine lid release. It's eaiser to pull than the stock round one. Really comes in handy if you have a cage like my car.....Performance Products part # 902429---$13.95
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I thought you found the ENGINE RELEASE knob. pull the knob and the motor falls on the ground.
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 06:30 AM |
