I'm ordering new calipers from Mr Shea., Should I get some speed bleeders? |
Rod |
Nov 2 2009, 04:15 PM
Senior Member Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I am fitting new discs all round , new Porterfield R4-S Pads, and have a new set of front calipers coming from MR Shea (IMG:style_emoticons/default/biggrin.gif)
Should I fit speed bleeders at the same time? (Does Eric sell them even?!) I'll change the fluid to DOT4 at the same time, and rather than pressurise the system and risk damaging MC I wondered if Speed Bleeders were a wise investment? |
tat2dphreak |
Nov 2 2009, 04:24 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
1) good choice on Eric! I love my rebuilt calipers from him
2) yes, speed bleeders are the shit! he DOES sell them 3) I think he also sells super-blue brake fluid. |
underthetire |
Nov 2 2009, 04:28 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Don't forget the new brake lines. And the Bosch spark plugs you know you can't find locally and....and....and...
Rod |
Nov 2 2009, 04:33 PM
Don't forget the new brake lines. And the Bosch spark plugs you know you can't find locally and....and....and... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/av-943.gif) |
biosurfer1 |
Nov 2 2009, 05:04 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Just don't lose the speed bleeders 2 weeks after you buy them...ask me how I know:/
VaccaRabite |
Nov 2 2009, 06:19 PM
En Garde! Group: Admin Posts: 13,629 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Speed bleeders are great, so long as you don't use a pressure bleeder to bleed your breaks.
Speed bleeders have a check valve in them that keeps the fluid from back filling air like a usual bleeder valve. But, the check valve needs more then the 10 - 15 psi pressure that is used by my pressure bleeder. If you want to use a pressure bleeder, stay standard. If you don't have one, speed bleeders are the bomb. Zach |
bandjoey |
Nov 2 2009, 06:33 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
How Do They Work? (IMG:style_emoticons/default/unsure.gif)
underthetire |
Nov 2 2009, 07:01 PM
Lo-Fi Version | Time is now: 4th January 2025 - 08:07 PM |
