gary gartner |
i know more than a newbie---way less than a guru ![]() ![]() Group: Members Posts: 239 Joined: 16-December 04 From: Valencia, Ca Member No.: 3,294 Region Association: Southern California ![]() |
been thinking about a 3rd brake light for a while now found a 10 lamp unit at http://www.commandelectronics.com/ mdl 003-74r and good price at $29.99 brakes on, virtually dissapears when off ![]() |
gary gartner |
Sorry, need to get the "ON" picture resized be back later gary |
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
Got any install as you go pics. Wheres the wire.
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
Sorry, need to get the "ON" picture resized be back later gary (IMG:style_emoticons/default/drooley.gif) Can't wait to see the "on" pic. That's the best 3rd brake light application I've seen on a 914. Might have to do that someday. Price is right too. Every time I see a GMC bumper out the back glass or in the side mirrors, I'm reminded of how low my 914 is, not to mention my taillights. Feel like a 3rd brake light would look cool and be a good safety addition. |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Looks like it's made to mount flat and the bulbs would then be pointing down. Did you make some type of bracket to mount on? CAn you post some photos of the install? Thanks Much!
This is the slimest design I've seen yet. |
flipb |
It's supposed to be watertight... wonder if it could be mounted above the raintray, underneath the leading edge of the mesh screen. Pretty much all modern cars are taller than the 914, so it should be visible to whoever's behind you.
(IMG:style_emoticons/default/idea.gif) |
gary gartner |
OK resized (I hope) installed with double stick foam tape and did a temp wire install by sticking to the underside of the rollbar with silicone, and hooked the wires into the bundle-power to a black with yellow brake line and ground to the brown. pretty simple, but no pics of the install. but no bracket needed cause it is only about 1/2in thick. ![]() |
gary gartner |
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Very cool! (IMG:style_emoticons/default/thumb3d.gif)
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,474 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
What model number did you get? Can't tell from the picture. Very nice job on the install!
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
003-74r
Under 3rd Brake Lights and in the LED section. |
flipb |
Is wiring as simple as just tying into the brake light circuit? Does it decrease the brightness of the brake lights noticeably?
I just ordered a different one - gonna try the hidden install under the vent, above the rain tray. Will post pics when I receive it and do the install. |
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
I wonder what that light strip would look like if it was put inside the aluminum trim piece right above it.....hmmmm....
tracks914 |
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None ![]() ![]() |
I wonder what that light strip would look like if it was put inside the aluminum trim piece right above it.....hmmmm.... Like this!!! BTW Nice work Gary. Attached image(s) ![]() ![]() |
tracks914 |
more
Sleepin |
Yes, like that....just all the way across. I wonder what the depth of the flexible strip lights are.
edit: something like this might fit under the bar and with 24 carefully drilled holes would blend seamlessly! (IMG:http://www.vista24.biz/ebay/tpschc/v2bm6314c.jpg) |
JazonJJordan |
Member ![]() ![]() Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States ![]() |
Awesome Guys! Those look great! (IMG:style_emoticons/default/piratenanner.gif)
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Looks great. (IMG:style_emoticons/default/beerchug.gif)
I used a Corvette 3rd light mounted on the engine lid. I do like the hidden in the roll bar chrome also. Attached image(s) ![]() ![]() |
montoya 73 2.0 |
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 07:11 PM |
