VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
My caution light knob glows a little when the headlights are tuned on. I thought this was an indication of a short. But in my winter project thread, I saw this:
QUOTE Zach, correct me if I'm wrong; but shouldn't the caution light knob illuminate dimly when the light switch is activated? So now I am confused. Can anyone clear this up for me? Am I chasing a short, or am I chasing a ghost? Zach |
Millerwelds |
Pleepleus ![]() ![]() ![]() Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California ![]() |
Mine has a slight glow too (not that answers your question, but at least you are not alone). (IMG:style_emoticons/default/drunk.gif)
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Not sure what you mean by caution light? Alternator dummy light? Should not glow unless there is a problem w/ alt. charging ect.. I doubt you have a short but maybe an excessive current draw or failing alt., voltage regulator ect. Mine never glows it di lite up like christmas when my alt. failed like a screeming banchee..
Millerwelds |
Not sure what you mean by caution light? Alternator dummy light? Should not glow unless there is a problem w/ alt. charging ect.. I doubt you have a short but maybe an excessive current draw or failing alt., voltage regulator ect. Mine never glows it di lite up like christmas when my alt. failed like a screeming banchee.. In my case I mean the hazard light switch itself. |
VaccaRabite |
Yes, the hazard light switch itself.
Turn on the head lights, and it glows slightly. This has nothing to do with dash idiot lights. Zach |
bobhasissues |
seemingly endless issues with my 914 ![]() ![]() Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None ![]() |
My caution light knob glows a little when the headlights are tuned on. I thought this was an indication of a short. But in my winter project thread, I saw this: QUOTE Zach, correct me if I'm wrong; but shouldn't the caution light knob illuminate dimly when the light switch is activated? So now I am confused. Can anyone clear this up for me? Am I chasing a short, or am I chasing a ghost? Zach Mine does the same thing, I think you are chasing a ghost |
ws91420 |
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region ![]() |
The hazard light switch has a bulb in it for illumination. The only switch on the dash that has a bulb actually in the switch. No short it normal.
ws91420 |
Also a fog light switch may do this also I think.
detoxcowboy |
caution light? i am sorry about the alt. light info. yes it lights up with head light on, fog light lights up when its pulled, same for defrost..
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,341 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Mine has always done that, don't know why?
VaccaRabite |
Well, now I know, and (IMG:http://blog.mattalgren.com/wp-content/uploads/2009/07/knowing-is-half-the-battle.jpg)
I think I am just going to check this one off my list as "complete" Zach |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Hazard, fog, and rear window defog all illuminate.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,998 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
According to the schematics, when the flasher is off and the lights are on, the hazard switch light will light gently. There is a resistor in series with the lamp to dim it when the flasher is off and the lights on.
Also the flasher lamp is fed from the dashboard dimmer knob on the light switch so the lamp should also dim with the rest of the dashboard lights. When pulled, the hazard switch light is connected directly to the turn signal lamps and will flash between full brightness and full off. The resistor mentioned before is not in this circuit. |
VaccaRabite |
I have a dimmer switch for my dash board lights?
How long have I had this car, and I did not know that? Zach |
SirAndy |
I have a dimmer switch for my dash board lights? How long have I had this car, and I did not know that? Yes. The light switch knob rotates. Left means darker, right means less dark. Note that i did not use the word "bright". (IMG:style_emoticons/default/shades.gif) Andy |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Left means OFF with your LED lights (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 2nd July 2024 - 11:09 PM |
