machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
like the way it fits and has in and out on one side.
anyone? Attached image(s) ![]() |
porsche735 |
Member ![]() ![]() Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 ![]() |
If you want it you can buy my car....LOL
It is a modified RX-7 oil cooler that has had AN-12 fittings welded to it. Works very well. Fits just perfect... We cut holes in the space for the steering rack to vent the air... Chris |
machina |
your ad says its a mocal, any idea the part number?
thanks, dr |
porsche735 |
Not sure. It has Mocal printed on it and I have the Mocal sandwitch plate thermostat. I bought it off eBay a while back and the guy had it on his 911.
Chris |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Fluidyne makes one almost identical to Chris'
B |
machina |
brad, do you know if they can put inlet and outlet on the same side?
this one you like has one on each side. thanks, dr Attached image(s) ![]() |
porsche735 |
http://www.fluidyne.com/pl_theoc.html
DB30417 is close 15"x6"x3" Chris p.s. Or look on eBay for modified RX-7 oil coolers....;-) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
That looks a lot like the one have and was thinking of using. I haven't got a clue what it's off of...anyone?
It's 2" X 5-3/4" X 22" I would have to bend the sheet metal like on chris' teen to make it fit. Attached image(s) ![]() |
Mark Henry |
What do ya'll think...the price was right, it was free!
CU of the in/out side Attached image(s) ![]() |
1973914 |
Member ![]() ![]() Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 ![]() |
Synthesis,
Looks a heck of a lot like the one that Patrick Motorsports sells. The outlet is 12AN, but i use a step down for my 10AN lines to my big four. Nice unit, but runs in the plus $400 range. Fits PERFECT for the standard 914/6 gt replica bumper opening. |
RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
What you have Mark is an early Mazda rx-7 oil cooler.
That type was used from 79-85. Later ones,from 86-91 are the same unit but the only difference is that one line comes in the side of the end tank. I have several,from both styles and usually look for the later ones in junkyards.I've bought'em mostly for 10-20 bucks. I get later ones,because of this reason.Both are mounted under the radiators of most RX-7's.just up the hood and look,either it'll have one or not,ya got a 50-50 shot.The early ones are mounted wide open to the road,nothing to protect them from sand and rocks.Consequently the early ones are packed with dirt,rocks,and the bottom row of cooling fins get rusted out from road water. The later cars had a plastic shroud installed to protect the cooler,hence they tend to have less damage to them after 10 or 15 years in the car. I'll take some photo's over the weekend of the unit I have in my 6'r.It is MUCH modified,seeing as I'm running -16 lines to feed it. on mine,I cut the end tank of,then flanged it so it could be taken apart for cleaning periodically. Ron |
RON S. |
Here are some pics of the mazda unit I've chose to try out.
RON S. |
NEXT 1
RON S. |
#3
RON S. |
I had the flanges waterjetted,then tig'd on,then milled flat.
RON S. |
Previous pic is of a framing pc I drew on cad then lasercut to fit under car,when I spotwelded it in place,it significantly stiffened the front trunk floorpan.
This shot is an early prototype I had laying around. Attached image(s) ![]() |
East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,699 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
Ron, Did you do away with the internal thermostat?? I have the same cooler and was considering using it for my 3.6. Are you using a fan of any sort??
RON S. |
this is the louvered pc I laser cut
RON S. |
This shot should show car bottom closed up
RON S. |
internal thermostat was removed,it is a big restriction to oil flow.
So now you wanna fan pic hey! Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:44 AM |
