naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
I am in the process of re-wiring all of Papa Smurf...well at least most of him. And I need to make sure I have the right gauge wire before I get started. I've already ripped out most of the non-essential wires, and want to replace a lot of the wires I already have, and insert a bunch of weather-pack connectors to make working on it much easier.
so, here's basically what's left: Ignition brake lights gauges fuel pump accessories (cool suit, radio, etc) signal wires (oil temp, oil pressure, tach) Can I use 14 gauge wire on most of these, except the main power/ignition? What should I use for that? thanks |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
what gauge wire where? If i'm not mistaken, the Haynes wiring diagrams (or the current flow diagrams) have the wire gauge printed on them. (IMG:style_emoticons/default/bye1.gif) Andy |
davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
what gauge wire where? If i'm not mistaken, the Haynes wiring diagrams (or the current flow diagrams) have the wire gauge printed on them. (IMG:style_emoticons/default/bye1.gif) Andy Yes, they do. However, the diagrams call out area in square mm, which is the European convention, rather than wire gage, which is the US convention. You'll need to find a chart to convert between the two. |
neil30076 |
Recovering dismantler! ![]() ![]() Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region ![]() |
Yes, they do. However, the diagrams call out area in square mm, which is the European convention, rather than wire gage, which is the US convention. You'll need to find a chart to convert between the two. This page http://www.sengpielaudio.com/calculator-cross-section.htm has all the cross section to AWG conversions down towards the end of the page. |
naro914 |
Yes, they do. However, the diagrams call out area in square mm, which is the European convention, rather than wire gage, which is the US convention. You'll need to find a chart to convert between the two. This page http://www.sengpielaudio.com/calculator-cross-section.htm has all the cross section to AWG conversions down towards the end of the page. Neil, wow this is great. Gotta bookmark this page. OK, so if I'm reading this right, if the wire on the Hayes manual says 1.0, that translates to a 17 gauge, I should be fine with 16 gauge wire there. |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Thin wires get hot faster. I would use the 14 gauge. it should be good for 20 amps at 12 volts. use 16 only for the gauges.
r_towle |
on papa you should use 10 gauge to prevent it from spontainiously combusting when you park it next to huey
Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 06:13 AM |
