WoodOne337 |
Newbie ![]() Group: Members Posts: 40 Joined: 3-October 07 From: Irving, Texas Member No.: 8,184 ![]() |
I would like to buy an air deflector that is attached to the pan just in front of the motor. I have attached a picture to show the piece that I am looking for. I am not sure if there is a difference between the left and right sides, but I am looking for the right side.
Thanks, Scott Attached image(s) ![]() ![]() |
kkid |
Member ![]() ![]() Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California ![]() |
What a coincidence!
I bought one today @ EASY in Emeryville CA. I paid $5. My car was missing on the driver side. Left and right are interchangeable with 4 bolt holes. I've checked with Parts Heaven but they are 3 time more expensive than EASY. |
WoodOne337 |
What a coincidence! I bought one today @ EASY in Emeryville CA. I paid $5. My car was missing on the driver side. Left and right are interchangeable with 4 bolt holes. I've checked with Parts Heaven but they are 3 time more expensive than EASY. By chance would anyone have a part# for this item? Thanks, Scott |
kkid |
I think it's 91455916310. When I last checked with PP, was told they were discontinued.
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,166 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I have ONE left, check the ad linked in my signature. (IMG:style_emoticons/default/smile.gif)
plas76targa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region ![]() |
I've been looking for these too! After WoodOne337 gets his, if anyone else has these please PM me.
c12croft |
Member ![]() ![]() Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 ![]() |
(IMG:style_emoticons/default/idea.gif) The description is in the name, however
what function do these perform in terms of the engine's operation? |
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
(IMG:style_emoticons/default/idea.gif) The description is in the name, however what function do these perform in terms of the engine's operation? They create a turbulence, forcing air in the correct directions to assist with cooling. |
c12croft |
(IMG:style_emoticons/default/idea.gif) The description is in the name, however what function do these perform in terms of the engine's operation? They create a turbulence, forcing air in the correct directions to assist with cooling. Where is the proper location for their install? In engine bay or beneath car near rockers as depicted? thanks, |
rascobo |
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest ![]() |
Where is the proper location for their install? In engine bay or beneath car near rockers as depicted? thanks, [/quote] They mount to the underside of the spot-welded flange where the floor pan meets the engine fire wall. You'll probably find the existing holes when You look close unless you have an early model, in which case You'll need to have someone measure theirs and let you know. Also,the side w/cross hatching faces engine compartment. Scott |
Lo-Fi Version | Time is now: 20th June 2024 - 05:49 AM |
