Fabric covered fuel line, FI rated? |
mtndawg |
Jan 8 2010, 09:22 AM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I have 3 lengths of fuel line and vacuum line (9mm) left over after replacing those in my engine compartment. I picked them up at AA, and yes I mixed them up. They're covered with gray fabric, how do I know which is FI rated? Is the all the gray FI rated? I want to use one of the lengths under my fuel tank.
Cap'n Krusty |
Jan 8 2010, 09:36 AM
The 9mm vacuum hose and the 9mm FI hose are the same product. Besides that, the lines under the tank are NOT pressurized.
The Cap'n |
VaccaRabite |
Jan 8 2010, 09:40 AM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The 9mm vacuum hose and the 9mm FI hose are the same product. Besides that, the lines under the tank are NOT pressurized. The Cap'n The line from the fuel pump to the tunnel connector is pressurized, for cars that have forward fuel pumps (75,76, any cars that have been modified.) Isn't the return line from the tunnel to the return feed on the tank also pressurized? (I don't remember, I have carbs and deleted the return line) In any case, if you call AA, they can tell you what they sold you more accurately then we can. Zach |
mtndawg |
Jan 8 2010, 11:21 AM
The 9mm vacuum hose and the 9mm FI hose are the same product. Besides that, the lines under the tank are NOT pressurized. The Cap'n Good point. (IMG:style_emoticons/default/blink.gif) Thanks Cap'n. The sending and returning line wouldn't be pressurized because the tank isn't pressurized. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:15 AM |
