911 Struts and Hubs |
rickthejetman |
Jan 12 2010, 09:13 PM
Member Group: Members Posts: 90 Joined: 5-May 09 From: victorville ,ca Member No.: 10,335 Region Association: None |
ok gang new guy question. if i have 1972 911 struts (boge) do i have to buy 72 hubs as well? or can i use later or earlier ones?
bdstone914 |
Jan 13 2010, 12:51 AM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
rickthejetman |
Jan 13 2010, 12:56 AM
ok gang new guy question. if i have 1972 911 struts (boge) do i have to buy 72 hubs as well? or can i use later or earlier ones? I have a pair of hubs that should fit your struts. I am in Riverside. If you come down here you can try them out. Bruce wow! thats awsome. i dont have them yet i was going to bid on them on ebay just wanted to see what my hub options were. i'll let you know if i win them. thanks a bunch |
ArtechnikA |
Jan 13 2010, 05:00 AM
ok gang new guy question. if i have 1972 911 struts (boge) do i have to buy 72 hubs as well? or can i use later or earlier ones? 1969 and later (which in 911-land is basically through 1989 at least) the spindles (and therefore hubs) are the same. (Technically, even the very early spindles and hubs are the same - but the very early struts are not, and if it were going to get iffy it'd be with the solid-rotor hubs.) |
Cap'n Krusty |
Jan 13 2010, 09:46 AM
Actually, the hubs aren't all the same. Hubs made for non-vented rotors are different. The Cap'n
rickthejetman |
Jan 13 2010, 12:51 PM
well i'm putting willwood brakes on so if either hub will work its fine with me. my niner has a wrx engine in it now. wanna make sure it will stop as fast as it will go now (IMG:style_emoticons/default/wink.gif)
ArtechnikA |
Jan 13 2010, 08:18 PM
Eric_Shea |
Jan 14 2010, 01:39 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
You can use them all but, they're all different.
Solod rotor hubs will work in a vented circumstance but your calipers will hit the wheels with most wheels. As they went to vented rotors the hubs widened the spacing. When they switched to A-Calipers they got an even wider stance. Good advice herein... stick with a 70+ hub and you should be good to go. |
rickthejetman |
Jan 16 2010, 02:19 PM
thank you all for the great advice. you have been most helpful
Mike Bellis |
Jan 16 2010, 04:19 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
well i'm putting willwood brakes on so if either hub will work its fine with me. my niner has a wrx engine in it now. wanna make sure it will stop as fast as it will go now (IMG:style_emoticons/default/wink.gif) You could alwasys try what I got on my car... 930 brakes with vented rotors. Not cheap though... Wilwoods are nice. I had them on my Mopar. Attached thumbnail(s) |
Spoke |
Jan 16 2010, 05:31 PM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
rickthejetman |
Jan 17 2010, 09:58 PM
rickthejetman |
Jan 17 2010, 10:00 PM
rickthejetman |
Jan 17 2010, 10:08 PM
sorry for the crappy cell phone pictures my digital is broken. i'm no fabricator i'm just an airplane mechanic thats learning this as i go along. so no mean coments on the poor quality. its strong it will hold thats all that matters to me.
rickthejetman |
Jan 17 2010, 10:14 PM
my trunk was totally rotten so it didn't bother me to cut it out. so my engine ended up nice and high and ground clearance is perfect.
Lo-Fi Version | Time is now: 26th December 2024 - 06:41 PM |
