> Welding Saftey around Gasoline?
detoxcowboy
post Jan 12 2010, 11:06 PM
Region Association: Africa
Ignornat questions but..
When welding in the front trunk A.C. hole is it safe not to pull the gas tank? Full tank gas better?
When welding in the engine compartment (shelf below battery where fuel lines have to be disconnected as they pass through that shelf) what do you do with open fuel lines, cap them? wet towel? Engine will be pulled so I could not just leave them connected unitl I finished??
I have no problem smoking around gas just welding is a little hot spark??
messix
post Jan 12 2010, 11:12 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
BOOM! (IMG:style_emoticons/default/welder.gif)
rick 918-S
post Jan 12 2010, 11:20 PM
Hey nice rack! -Celette
Pull the tank. It's not that hard. It only takes one mouse nest under the tank to open a can of whoopass you will regret. Move the rear lines over and you should be fine.
detoxcowboy
post Jan 12 2010, 11:50 PM
QUOTE(messix @ Jan 12 2010, 09:12 PM) *
(IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/welder.gif) Ba boooom!! Thanks Rick!! Just move the lines over but plug them correct? the engine is going to be out so there will be nothting just move them over connected..
Mouse Nest?? Do you mean seapage? There ain't no mice up front they all working the flywheel.. Seriously though under my tank is clean clean.. been in under there a few times this year, nothing but what the p.o. dropped golf tees and washers//.
messix
post Jan 12 2010, 11:53 PM
throw a big wet towel over the lines and keep them away from where your gonna weld and you'll be fine.
Rand
post Jan 13 2010, 12:12 AM
Cross Member
Echo Troy. Simple, no worries. Throw some wet towels over what scares you.
Keep ventilation open!
You wanna talk about real freaking out, my dad used to weld on gas tanks. He would hook a tube from the exhaust of a running car into the intake of a tank, let that flow a bit, and weld away.
aircooledtechguy
post Jan 13 2010, 10:18 AM
The Aircooledtech Guy
QUOTE(Rand @ Jan 12 2010, 10:12 PM) *
You do the same thing with aircraft. They call it gas-freeing the tanks. Blow enough air through a tank for a given period of time (depending on tank size) and fuel used. Viola! It's safe to weld on.
I knew a guy who would let a tank basically dry out for a 1/2 day, then, with a lit torch at arms length, go to the filler neck. A flame would shoot out for a second (read that: explode out). No more vapors. Safe for welding. THAT was a little foolish for my taste.
Scott S
post Jan 13 2010, 10:30 AM
Small Member
QUOTE(messix @ Jan 12 2010, 10:53 PM) *
I will be installing the Rick Johnson mount for my -6 conversion - is ot ok to go this route when dealing with the exposed ends of the center tunnel fuel lines?
Thanks!
sww914
post Jan 13 2010, 10:36 AM
I've done all the stuff they say to not do and I'm still equipped with enough fingers to type. Gas doesn't really light all that easily, IMO. But if it does light and there's a lot of it it gets loud.
ericread
post Jan 13 2010, 10:42 AM
The Viper Blue 914
There's always the idea of submerging the entire car in water, and welding under water. Much safer... (IMG:style_emoticons/default/rolleyes.gif)
Dr Evil
post Jan 13 2010, 02:26 PM
Send me your transmission!
I have heard of dry ice being used. Just drop a few chunks in the empty tank and it cools the tank as well as filling it with fire retardant CO2.
messix
post Jan 13 2010, 07:03 PM
QUOTE(Scott Schroeder @ Jan 13 2010, 09:30 AM) *
Thanks!
liquid gasoline is not all that dangerous.... but the vapor is!
just protect anything that you don't want splattered with welding sparks and that should have some flammable vapor, liquid or material. if yer gonna weld on the fire wall ya might wanna take the back pad out of the passeger compartment. (IMG:style_emoticons/default/slap.gif)
detoxcowboy
post Jan 13 2010, 07:05 PM
QUOTE(messix @ Jan 13 2010, 05:03 PM) *
Thanks!
Thanks Meesix for the tip, ..
ME733
post Jan 14 2010, 08:31 AM
(IMG:style_emoticons/default/popcorn[1].gif) ...Lots of mostly good Ideas , have been submitted. Consider this approach...!. REMOVE GAS TANK...blow out the disconnected fuel lines, shop air.....allow to air dry a day or two....2. move front and rear fuel lines , out of the way as far as possable. cover and wrap them with large soaking wet towels....3. have a FIRE EXTINGUISHER close by, and a hose with nozzle preadjusted for a spray pattern.(to cool , burning materials,and smother flames). (IMG:style_emoticons/default/popcorn[1].gif)
Geezer914
post Jan 14 2010, 05:39 PM
Geezer914
Pull the tank and plug the lines, why take a chance of ending up in a burn unit. Gas and sparks don't mix. Just ask the guy who tried to look in his gas tank to see how much gas was left and used a match.
Rand
post Jan 14 2010, 08:50 PM
Cross Member
It's not necessary to pull the tank and plug/flush the lines. Leave it connected and it's plugged/sealed by default. How is a welding spark going to get to the gas? If you have a leak? You could bounce sparks off your gas tank all day.
If you have wet gas puddling around, it will burn. If you have contained fumes it will explode!! Obviously make sure you don't have either. If you make sure you don't have leaks, you do have good ventilation, and throw a wet towel over anything that could leak fumes or be vulnerable to melting under a spark, it's just not a big deal!
The original question was about welding a front trunk AC hole. It's not like he's using a cutting torch to cut 1/2" plate right above the gas tank spout. But whatever. Do what makes you feel safe. I just don't like doing a bunch of unnecessary work for no valid reason.
detoxcowboy
post Jan 14 2010, 11:16 PM
QUOTE(Rand @ Jan 14 2010, 06:50 PM) *
Rand, I could not agree with you more; The input was varied quit a bit. I can see that I would not be in danger on the front or even engine comp, fumes or something extra I coud not see/understand which is one reason I asked to fill the tank first. If I created enough heat to penetrate that far I would not have a front trunk at all. The chance that I have a leak or even a small pool of gas under the tank is minimal as I have changed everything down there and have been under there a couple times this year. and the spark going the one in a million jump to down the opening around the tank to underneath and staying hot enough long enough to spark, it is crazy odds. I just asked in the begining to check prior as I do not think I know everyting. Wet towel ect. to be certain is good enough. I have spilled gas all over me and on the driveway before and I lighted cigs all through the ordeal.. Fumes have to be concentrated and i am bascially outside no garage.
All the input confirmed my original thoughts, thank you everyone.
There is another reason I ask about around gas safety. I loss 90% of my smell sometimes it is better than others but it can be dangerous, I have accidently inhlaed flooring stripper all day and did not realize how much unitl I got sick headache./.
Joe Bob
post Jan 14 2010, 11:50 PM
JB weld or pull the tank, fill with water...or have a pro do it. Unless you LIKE having no eyebrows and a dent in yer forehead.....
ChrisFoley
post Jan 15 2010, 04:39 AM
I am Tangerine Racing
QUOTE(Rico Suave @ Jan 15 2010, 12:50 AM) *
The OP isn't asking about welding a leak in the tank. (IMG:style_emoticons/default/rolleyes.gif)
Rand's advice is best. The chance of explosion is minimal working near the tank or lines unless confined vapors are sparked. At this time of year the only place where significant vapor concentration might exist is inside the tank itself.
detoxcowboy
post Jan 15 2010, 09:29 AM
QUOTE(Rico Suave @ Jan 14 2010, 09:50 PM) *
I already have a dent and a mono brow!
- Lo-Fi Version Time is now: 27th December 2024 - 01:50 PM
