> 2.7 Weber manifolds
Scott S
post Jan 18 2010, 12:11 PM
Small Member
Hi All
I am plugging away on the conversion - at least as time permits.... sigh.
I have the carbs (40 IDTP 13C), but have not picked up the manifolds. For the 2.7 do I run the normal 911 manifolds (part number 911101321R) with the 40 top bore and the 32 bottom bore? I need to know what to look for. If anyone has a set, I would love to chat.
The 2.7 is stock and I plan on using the PMO spacers.
As always, thanks a million...
-Scott S
carr914
post Jan 18 2010, 02:50 PM
Racer from Birth
I just sold a set a month ago, I don't have any more. You can also get the tall ones from PMO - They look better
vs
J P Stein
post Jan 18 2010, 02:54 PM
Irrelevant old fart
Most 2.7Ls have 35mm intake ports. IIRC, the 74 only 'Normal" 2.7L had 32mm intakes.
Whatcha' got?
Scott S
post Jan 18 2010, 03:03 PM
Small Member
Hi JP -
It is a 77 911S. I was just told that it needs 40 over 36. Is it 35 or 36? I just want to make sure I am looking/searching on line using the right terminology.
Thanks Again! (IMG:style_emoticons/default/beerchug.gif)
Scott S
J P Stein
post Jan 18 2010, 03:51 PM
Irrelevant old fart
QUOTE(Scott Schroeder @ Jan 18 2010, 01:03 PM) *
Hi JP -
Scott S
My 76 was 35mm which I opened to 36. According to the book, all the USA 2.7Ls were 35 mm intake ports. The exceptions were the "normals"(150 hp) and the RS (NA in the USA) at 36mm. The "short" manifolds (the black ones in TCs pic) can be opened to 35-36. The "tall" (PMO) are 36mm from the get go, IIRC.
The PMO insulators are 36 and (IMO)you want these and the manifolds as they block off the notch in the head as cast for the injector.
There are also plugs for the air injectors next to the exh port. Pelican & EBS carry these.
burton73
post Jan 18 2010, 05:16 PM
burton73
Scott,
My part number is 901.108.321.OR it was from an early S on my 2.5 69S
The size is 41mm over 38mm on a low dollar bullet loading plastic gauge.
I had early 69 ported S Heads that I sold to Mark and I am going to be running fresh 76 S heads.
Bob
- Lo-Fi Version Time is now: 26th December 2024 - 05:23 PM
