underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
After really looking at the cost of the rebuild of the GA i picked up, i started to think twice. Then a guy at work offered me a buick 231V6. Low mileage motor (he got it in 81). So, I know i need the adapter stuff and cooling, probably some other stuff like headers or other misc crap. Anyone have the 231 ? and how do you like it?
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
No idea (IMG:style_emoticons/default/popcorn[1].gif)
drgchapman |
Current Stable ![]() ![]() ![]() Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest ![]() |
I put a 231 into a '73 Vega back in 1978. Power was down low, not a rever. Good torque. Lots of motor torque over to control vs. the inline 4 it replaced. I think built to a different hp/torque curve it could be a lot of fun. I was looking for an aluminum small block buick v8, literally found this car, an Astre, I think, in a ravine and pulled the motor and transmission out on a skid.
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
After really looking at the cost of the rebuild of the GA i picked up, i started to think twice. Then a guy at work offered me a buick 231V6. Low mileage motor (he got it in 81). So, I know i need the adapter stuff and cooling, probably some other stuff like headers or other misc crap. Anyone have the 231 ? and how do you like it? So far (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/aktion035.gif) http://phoenixhobbies.com/html/first_drive.html http://phoenixhobbies.com/html/project_914.html There are a couple of others on the board maybe they will chime in. Paul |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
My friend has a Buick V6. It is fast. He does not participate on this board.
I though about doing something similar, but I don't want to cut up my car. |
underthetire |
After really looking at the cost of the rebuild of the GA i... What was your ballpark estimate? Heads 1K P/C 900 Cam/lifters/pushrods 500 bearings 350 or so oil pump gaskets machine work so i'm guessing if i do some of the case machining myself, and some of the head machining, about 3K. Them i'm still only in the 150HP range. Buick V6- free ring and gasket it, new valve springs-200 bucks (maybe free) Adapter with flywheel 500 motor mount bar 100 cooling i'm gonna buy a RX7 rad-200 bucks exhaust- not much since I have a mandrel tube bender at work Oh, might do a cam in it with lifters as well, but a very good friend of mine used to race the 231 and helped design the turbo regals, up to the GNX. He has a ton of stuff for these motors he does not use any more. Hell he even has 3 GNX complete crate motors still in the buick box. |
Phoenix-MN |
After really looking at the cost of the rebuild of the GA i... What was your ballpark estimate? Heads 1K P/C 900 Cam/lifters/pushrods 500 bearings 350 or so oil pump gaskets machine work so i'm guessing if i do some of the case machining myself, and some of the head machining, about 3K. Them i'm still only in the 150HP range. Buick V6- free ring and gasket it, new valve springs-200 bucks (maybe free) Adapter with flywheel 500 motor mount bar 100 cooling i'm gonna buy a RX7 rad-200 bucks exhaust- not much since I have a mandrel tube bender at work Oh, might do a cam in it with lifters as well, but a very good friend of mine used to race the 231 and helped design the turbo regals, up to the GNX. He has a ton of stuff for these motors he does not use any more. Hell he even has 3 GNX complete crate motors still in the buick box. I have a new Kennedy pressure plate, flywheel and disk for sale if interested Paul |
Lo-Fi Version | Time is now: 20th June 2024 - 06:09 AM |
