Tires again 205 50 or 60 |
jhelgesen |
Feb 12 2010, 08:34 AM
Newbie Group: Members Posts: 42 Joined: 14-July 08 From: Charlotte Member No.: 9,299 Region Association: None |
I've got a set of 2.0 fuchs to put on my stock fendered 75. Checking out tirerack, I can get 205/50's or 205/60 in Kumho's. Street car only.
Any fender issues with using the 60's? Thanks! |
detoxcowboy |
Feb 12 2010, 08:48 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I've got a set of 2.0 fuchs to put on my stock fendered 75. Checking out tirerack, I can get 205/50's or 205/60 in Kumho's. Street car only. Any fender issues with using the 60's? Thanks! No sir, I have 205/60 all around my 74 w/ 2.0 fuchs.. so do other people.. |
jhelgesen |
Feb 12 2010, 08:50 AM
I've got a set of 2.0 fuchs to put on my stock fendered 75. Checking out tirerack, I can get 205/50's or 205/60 in Kumho's. Street car only. Any fender issues with using the 60's? Thanks! No sir, I have 205/60 all around my 74 w/ 2.0 fuchs.. so do other people.. Sweet! What I needed to hear. I'll get them on order! |
zx-niner |
Feb 12 2010, 12:52 PM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
You will be much happier with the engine revs using 60s since you'll be mostly on the street
6freak |
Feb 12 2010, 01:16 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
205/50/15 NO ISSUES GO WITH THE BIGGEST YOU CAN |
6freak |
Feb 12 2010, 01:28 PM
You will be much happier with the engine revs using 60s since you'll be mostly on the street Maybe im all messed up but arent 50`s wider then 60`s 205 tire height 50 tire width 15 rime size why would 60 affect the revs and why would you put on a skinner tire then you have too?? |
Lavanaut |
Feb 12 2010, 01:43 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s.
Reid |
championgt1 |
Feb 12 2010, 01:44 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Mike you have height and width mixed up.
6freak |
Feb 12 2010, 04:01 PM
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s. Reid THANKS FOR SET`N ME STRAIT (IMG:style_emoticons/default/smile.gif) |
messix |
Feb 12 2010, 04:13 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s. Reid THANKS FOR SET`N ME STRAIT (IMG:style_emoticons/default/smile.gif) got your asshat on again huh? (IMG:style_emoticons/default/av-943.gif) |
70_914 |
Feb 12 2010, 04:21 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s. Reid THANKS FOR SET`N ME STRAIT (IMG:style_emoticons/default/smile.gif) Actually, to be more specific- 205=mm width (tire manufacturers measure at different spots so they are not all the same width. 50 or 60 is the aspect ratio. 50% the width tall, 60% the width tall, etc. So an sr16515 (which should be a 70 series) has a sidewall that is theoretically 115.5 mm tall. 205/50 should be 102.5, 205/55 should be 112.75, 205/60 should be 123. Taller tires = numerically lower gearing = no power around town, good RPM on the freeway. Kevin |
Shade Tree |
Feb 12 2010, 05:44 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I have 205/60's. I like the ride and the look. I think the taller tire fits the vintage of the car. However, I feel like I'm lugging the poor thing if I use 5th gear going 60mph. Since I almost never go any faster on a normal commute, I'm now sort of wishing I had the 50's so I would have a better chance of using 5th. 50's are a pretty bumpy ride imo.
jsayre914 |
Feb 12 2010, 06:14 PM
Speed Up !!! Group: Members Posts: 3,208 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
this is my second 914 and i have 205/60 on this one and the lasdt one. if you are driving 120+ miles daily, its not an option. I drive my car as hard as i can untill it breaks, then i take too long to fix it, and go again (IMG:style_emoticons/default/driving.gif)
i also love the look of the 60's |
detoxcowboy |
Feb 12 2010, 06:22 PM
I have 205/60's. I like the ride and the look. I think the taller tire fits the vintage of the car. However, I feel like I'm lugging the poor thing if I use 5th gear going 60mph. Since I almost never go any faster on a normal commute, I'm now sort of wishing I had the 50's so I would have a better chance of using 5th. 50's are a pretty bumpy ride imo. I have heard 50's are bumpy, never had a problem with 5th gear on 60's but in Los Angeles it is either 1st/2nd gear on the freway or 80 mph just to keep up.. |
EdwardBlume |
Feb 12 2010, 06:30 PM
I liked 205 / 60 s with a 1/4 inch spacer. Filled out nice! You need longer bolts for the rear though...
markb |
Feb 12 2010, 08:31 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I've had 205 70's, 60's & 50's, and I prefer the 60's. I drive a lot of highway miles, and they're better for me on the highway. I currently have 70's on the car, and can't wait to get back to 60's.
Michael N |
Feb 12 2010, 09:34 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
sww914 |
Feb 12 2010, 09:48 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
50's on my racecar, 60's on my street car. I'm buying new street tires soon, I'll put 60's on again. They're just right.
6freak |
Feb 12 2010, 09:58 PM
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s. Reid THANKS FOR SET`N ME STRAIT (IMG:style_emoticons/default/smile.gif) got your asshat on again huh? (IMG:style_emoticons/default/av-943.gif) Always ....hey thanks again for coming over last Saterday Troy |
messix |
Feb 12 2010, 10:46 PM
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s. Reid THANKS FOR SET`N ME STRAIT (IMG:style_emoticons/default/smile.gif) got your asshat on again huh? (IMG:style_emoticons/default/av-943.gif) Always ....hey thanks again for coming over last Saterday Troy you know my situation now, i'm sorry i couldn't make it. i sent a gift though. |
Lo-Fi Version | Time is now: 5th January 2025 - 01:34 AM |
