RonnieJ |
RonnieJ ![]() ![]() Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest ![]() |
I have a 1.7 running dual webers and it will surge a little while at idol. It only comes up a couple hundred rpms's and then right back down.I want to find what the problem is and make it right...Any ideas? Carbs loading up?
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
I have a 1.7 running dual webers and it will surge a little while at idol. It only comes up a couple hundred rpms's and then right back down.I want to find what the problem is and make it right...Any ideas? Carbs loading up? If compression dwell timing are right on and not moving, then leanness caused by bad carb adjustment or a vacuum leak |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
or a sticking advance in the dizzy. And I hate American Idol.
RonnieJ |
Thanks guys much appreciated.
Lo-Fi Version | Time is now: 24th June 2024 - 11:31 PM |
