kconway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California ![]() |
I need some help identifying the correct clip for the transition from hard to soft brake lines at the strut. I have what I believe are early "T" 911 struts. The hard point on the strut where the lines attach are different than my 914 struts. The clips I bought appear to be too large and I don't want to blow it again. Can someone confirm my suspicions and perhaps point out the correct part number I need. The clips I have are 914-355-653-00, Pelican says I should be using 911-355-653-05 but need to confirm they're not the same part before I buy.
Also, should I be replacing the hardlines while I'm here or do they look "servicable"? Thanks! (IMG:style_emoticons/default/beerchug.gif) Kev ![]() ![]() ![]() ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Wrong clip. (IMG:style_emoticons/default/sad.gif)
Attached image(s) ![]() ![]() |
kconway |
Thanks Mark, Any idea on the part number? Looking at the diagram on Pelican, the one shown looks alot like what I've got. Kev |
McMark |
The PET for 70-73 911 give me this PN: 803 611 715 which works in the Pelican search.
But I like GPR. |
McMark |
And your brake hose may be wrong too.
kconway |
It's the damn $2 part that always brings my progress to a screeching halt! (IMG:style_emoticons/default/dry.gif)
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Kevin, there are two ways around this.
1. Use the 911 U-shaped hat style clip or, 2. Install your current clip horizontially vs. vertical (as you're showing). You would have to grind about 1/4" off the ends of the tabs. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:57 AM |
