McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
![]() I'm now offering this speedo drive gear modification to help seal one of the more persistent leaks on the 914 transmission. By adding a second, lower o-ring to this part it not only gains a second barrier again leaking, but also helps reduce the vibration that can wear the clearances and cause further leaking. This part sits inside the transmission tail cone and the angle drive screws into it, then the cable attaches to the angle drive. ![]() The new internal seal is noticeably smaller on the ID. This means more sealing pressure against the gear shaft, and therefore better sealing against oil leaks. ![]() Now available HERE from 914Rubber. This member (Thanks Eric!) had a significant leak at the speedometer, even while parked. After this modification was done... ZERO LEAKS! Read his story here. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,177 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Great idea! (IMG:style_emoticons/default/smilie_pokal.gif)
After years of abuse, the case often is slightly oval allowing for oil to seep by. A second o-ring should take care of that ... (IMG:style_emoticons/default/w00t.gif) Andy |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
VERY COOL!!! You get a gold star McMark!!!!
whatabout1 |
Toys in Red ![]() ![]() Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None ![]() |
PM sent
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,985 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
This looks cool. Mine doesn't leak that I know of but I will keep it in mind...
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Awesome!
McMark |
These are now available only as complete rebuilds, all new o-rings, a new internal seal, and a new sealing washer. No compromise, no second guessing, no leaks.
eyecolor |
Eyecolor ![]() ![]() Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None ![]() ![]() |
Count me in
Tell me how to pay and where to send the core thanks George |
McMark |
PayPal: $65 to mark@originalcustoms.com
Core: Original Customs 19660 Eighth St East Sonoma, CA 95476 |
McMark |
Sleepin' posted his experience with the speedo modification. Read about it here.
jflash914 |
Member ![]() ![]() Group: Members Posts: 80 Joined: 24-February 05 From: binghamton,ny Member No.: 3,652 ![]() |
McMark, Besides removing the set screw what else is needed to remove the speedo drive?? Do you have to remove the back plate of the trans to get the drive shaft out? Thanks, Jack |
BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
When I removed my speedo drive for my track day car, I machined a plug with two 0 rings with a centered trans temperature probe. Seemed the prudent thing to do.
No leaks! I never thought of offering a simple modification like this on the speedo drive. Great Idea! |
McMark |
Jack, once the set screw is removed the speedo drive just pulls out. They can get quite stuck sometimes though. Leaving the angle adapter in place will help give you a place to grab.
Make sure the transmission is drained, or the rear end is HIGH up or the gear oil will drain out all over. |
jflash914 |
Jack, once the set screw is removed the speedo drive just pulls out. They can get quite stuck sometimes though. Leaving the angle adapter in place will help give you a place to grab. Make sure the transmission is drained, or the rear end is HIGH up or the gear oil will drain out all over. Thanks McMark |
Kevins911 |
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-July 05 From: Kelowna, B.C. Member No.: 4,420 Region Association: Canada ![]() |
Hi Mark, just wondering if you are still making these? I sent you a pm.
Cheers Kevin |
McMark |
Yes I am. I'm waiting on more seals from Porsche, but as soon as they come in more will be ready to ship.
Ericv1 |
Member ![]() ![]() Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest ![]() |
Yes I am. I'm waiting on more seals from Porsche, but as soon as they come in more will be ready to ship. What's the turn around time? I just degreased my transmission (in the middle of a six conversion) and found it is leaking at the angle drive. Do I need to send the drive gear as well as the housing? Thanks. |
McMark |
Turn around time is one day. The only piece I need sent is the piece pictured at the top of this thread. Not the angle drive, not the geared shaft.
SUNAB914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States ![]() |
Hey I will order one as soon as I get settled in on my move. Be contacting you in Jan.
McMark |
Gear seal kits are now available with the speedo drive for a completely leak free transmission. Seal kits are only $17.50. (IMG:style_emoticons/default/sunglasses.gif)
Lo-Fi Version | Time is now: 10th April 2025 - 06:16 AM |
