Wiring MSD 6AL to 3.0 6 |
bag5rcg |
Mar 8 2010, 01:38 PM
Member Group: Members Posts: 80 Joined: 20-February 06 From: Dallas, Ga Member No.: 5,607 |
Hi Gang,
Has anybody out there wired up an MSD 6AL to a 3.0 6 with a regulated alternator?....I am afraid to play too hard with it because I don't want to start burning up components (IMG:style_emoticons/default/blowup.gif) during the effort which would lead to chasing several problems rather than one. I also cannot get my car to do ANYTHING with the relay board attached (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/wacko.gif) ....I am playing with the idea of bypassing the relay board all together by replacing the female style plug (on the engine side) with a male style plug that would plug into the chassis plug directly (IMG:style_emoticons/default/idea.gif) .... Any thoughts, suggestions would be appreciated..This is the very last engineering hurdle in a 4 year restore/6 conversion Thanks |
Justinp71 |
Mar 8 2010, 02:35 PM
Senior Member Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I did this last year with a internal regulated alternator. I'm not sure why it makes a difference? I thought you just connect power up to MSD and then plug the dizzy into the port on the MSD... I can take a better look tonight and let you know...
also I have seen the relay boards removed on cars with internally regulated alternators... |
SirAndy |
Mar 8 2010, 02:43 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
No more relay board ...
I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board. (IMG:style_emoticons/default/driving.gif) Andy (IMG:http://www.914world.com/bbs2/uploads/post-179-1202450158_thumb.jpg) |
bag5rcg |
Mar 8 2010, 03:00 PM
I did this last year with a internal regulated alternator. I'm not sure why it makes a difference? I thought you just connect power up to MSD and then plug the dizzy into the port on the MSD... I can take a better look tonight and let you know... also I have seen the relay boards removed on cars with internally regulated alternators... Dizzy?????...Is that an add on module? |
SirAndy |
Mar 8 2010, 03:08 PM
Dizzy?????...Is that an add on module? Dizzy = Distributor (IMG:style_emoticons/default/shades.gif) Andy |
70_914 |
Mar 8 2010, 03:11 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
I did this last year with a internal regulated alternator. I'm not sure why it makes a difference? I thought you just connect power up to MSD and then plug the dizzy into the port on the MSD... I can take a better look tonight and let you know... also I have seen the relay boards removed on cars with internally regulated alternators... Dizzy?????...Is that an add on module? Dizzy = Distributor I have hooked 6AL boxes up to VW's with generators and external regulators, VW's with internally regulated alternators, Fords with internally and externally regulated alternators. The MSD box does not care. If you look at the voltage specs it is good from, IIRC, 9-17 volts. They also have a nice fuse built in to protect it. Plug and Play! |
Jeffs9146 |
Mar 8 2010, 03:16 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE No more relay board ... I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board. Is that something I should get for my 3.0L that I am putting into the 6? |
SirAndy |
Mar 8 2010, 03:23 PM
QUOTE No more relay board ... I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board. Is that something I should get for my 3.0L that I am putting into the 6? It made for a much cleaner install. (IMG:style_emoticons/default/thumb3d.gif) Call PMS and see if they make one for your application. Just make sure you double check the connectors/wires before you plug it in. They had two wires mixed up on mine ... (IMG:style_emoticons/default/dry.gif) Andy |
bag5rcg |
Mar 8 2010, 03:42 PM
Dizzy?????...Is that an add on module? Dizzy = Distributor (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/biggrin.gif) Thanks |
Justinp71 |
Mar 8 2010, 03:47 PM
QUOTE No more relay board ... I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board. Is that something I should get for my 3.0L that I am putting into the 6? If your running carbs I wouldn't bother, the only connections on my carbed motor are to the alternator and the dizzy. If you're running CIS you might consider it if patricks even offers it. Andys motor is a motronic 3.6, so it makes more sense to use it on his application... |
Scott S |
Mar 8 2010, 03:48 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Drop Perry Kiehl a line. He just sent me a fantastic wiring harness for my conversion that incorporated everything from the Pertronix to the MSD in what appears to be a factory harness. It elimintes the relay board and plugs directly into the factory harness. It is SO cool...
rfuerst911sc |
Mar 8 2010, 05:47 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I recently picked up my 3.0 conversion from my mechanic. He used the relay board and it looks like he only added one wire to it. The factory harness is plugged into the board I guess to run other items. Also using a internally regulated alternator.
Jeffs9146 |
Mar 8 2010, 07:07 PM
QUOTE I recently picked up my 3.0 conversion from my mechanic Is it FI or Carbs? I am going to try to run FI! |
bag5rcg |
Mar 8 2010, 07:24 PM
Yep...Looking like the the new harness with the male plug is the way to go....I may check out what Perry has to offer (is he on the board??)...Thanks for all of the input!
Justinp71 |
Mar 9 2010, 10:33 AM
QUOTE I recently picked up my 3.0 conversion from my mechanic Is it FI or Carbs? I am going to try to run FI! Are you refering to the factory CIS or an actual FI system? In my opinion I would only do Motronric, carbs or a throttle body injection system. The fi systems can run good, but I hear its a lot of work and many have horror stories. I would have loved to run motronic on my 3.0 but its requires a bit of machining to the heads, so I went with carbs! I think they're totally awesome and I get around 17-20 mpg (motronics I think get 25-30). |
rfuerst911sc |
Mar 9 2010, 01:57 PM
Lo-Fi Version | Time is now: 26th June 2024 - 12:52 AM |
