underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
My first ignitor was a Hot Spark, It looks and acts just like the Pertronix unit with the small magnet ring. Worked fine until I had a small melt down, not the hot sparks fault (IMG:style_emoticons/default/biggrin.gif) . What I had noticed since I use the megasquirt, and put my scope meter on it to confirm, is during cranking i never got a nice clean square wave signal out of it. Once started , it was fine. This time I opted for the Compu fire conversion, since this has a large disk that passes over the top of the sensor. The disk has small magnets on the outside edge, allowing a higher surface speed over the sensor. Cranking signal has cleaned up by a factor of 2 to 1. My idle is now way more solid than with the little ring magnet sensor type of pickup. So, in conclusion, the signal coming from the Compu-fire is much cleaner, allowing better idle control for my application. 2 weeks in so far. I obviously can not attest to longevity yet.
Either one IMO works well for carbs, or stock FI, but so far, I prefer the compufire for my aftermarket FI. Attached thumbnail(s) ![]() Attached image(s) ![]() |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Thanks for the insight.
I no longer have access to a scope to check the signal output from something like that. Cleaner signal means a greater chance of firing on time. Now you get to do the reliability test for us to see how long the parts will work. Also might want to check signal degredation over time to see how the parts hold up. The engine environment (heat, vibration) can cause sensors to crap out. I know the dizzy sensors in my wasserboxer Vanagon craped out at about 60k. |
underthetire |
Thanks for the insight. I no longer have access to a scope to check the signal output from something like that. Cleaner signal means a greater chance of firing on time. Now you get to do the reliability test for us to see how long the parts will work. Also might want to check signal degredation over time to see how the parts hold up. The engine environment (heat, vibration) can cause sensors to crap out. I know the dizzy sensors in my wasserboxer Vanagon craped out at about 60k. Easy enough to do, but 60K will be like 10 years from now ! |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
yep, I had a compufire in my 009, before I changed distributors and installed a Crane XR700 the compufire is a good unit imo.
Cap'n Krusty |
One of Compufire's main product lines is for Harleys. I wouldn't be too afraid of heat/vibration problems ...............
The Cap'n |
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
Which Compufire unit did you install? The 21100 or the 21101? I am willing to try it on my daily driver.
Currently I user the Pertronix unit, but if you say I can get a more reliable spark, I'd like to try it. At 15,000 miles a year, it'll be easier for me to get real world reliability data. Eric |
underthetire |
I'll check the part number when I get home. A guy in LA doing VW stuff was 62.00 dollars for it and got it in two days. The local shops up here were 120 and 99 dollars.
underthetire |
I'll check the part number when I get home. A guy in LA doing VW stuff was 62.00 dollars for it and got it in two days. The local shops up here were 120 and 99 dollars. Oops 63.95 Powerhaus 310-328-2746 John I just got the one for the 050 dist, fits fine, just be careful how you route the wires around the advance plate. |
Cap'n Krusty |
The 050 doesn't have an advance plate ..............
The Cap'n |
underthetire |
The 050 doesn't have an advance plate .............. The Cap'n I know, but I have sorta a hybrid dizzy, since I didn't want the tall can with the injector points. Anyway, I think the difference was the old old style points vs the 009 or our style points. Something about the pin being on the opposite side on the advance plate on the old VW ones. You's probably know better than me what was what. |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
My first ignitor was a Hot Spark, It looks and acts just like the Pertronix unit with the small magnet ring. Worked fine until I had a small melt down, not the hot sparks fault (IMG:style_emoticons/default/biggrin.gif) . What I had noticed since I use the megasquirt, and put my scope meter on it to confirm, is during cranking i never got a nice clean square wave signal out of it. Once started , it was fine. This time I opted for the Compu fire conversion, since this has a large disk that passes over the top of the sensor. The disk has small magnets on the outside edge, allowing a higher surface speed over the sensor. Cranking signal has cleaned up by a factor of 2 to 1. My idle is now way more solid than with the little ring magnet sensor type of pickup. So, in conclusion, the signal coming from the Compu-fire is much cleaner, allowing better idle control for my application. 2 weeks in so far. I obviously can not attest to longevity yet. I can(attest to longevity)!! 7 years and still working(Pertronix)and there is a few other's on this board with more longevity,sorry I'm sticking with it (IMG:style_emoticons/default/shades.gif) Later |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
I can(attest to longevity)!! 7 years and still working(Pertronix)and there is a few other's on this board with more longevity,sorry I'm sticking with it (IMG:style_emoticons/default/shades.gif) Later (IMG:style_emoticons/default/agree.gif) I know someone who has an Ignitor in his old Ford pickup that I sold him and it has been in the truck since the mid 80's.... |
underthetire |
I can(attest to longevity)!! 7 years and still working(Pertronix)and there is a few other's on this board with more longevity,sorry I'm sticking with it (IMG:style_emoticons/default/shades.gif) Don't be sorry. I don't care (IMG:style_emoticons/default/biggrin.gif) If what you have works for you, great. I'm just posting what I found to possibly help others. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I had a compufire in a 009 and it was missing and farting when hot.The same 009 with points worked OK but it had the crappy 009 flat spot. I modified a pertronix to work in a mallory (points) dizzy and it works great.
Most peeps have good luck around here with them, but there have been a few failures. If you are using it as a trigger for the MS ignition then signal quality is probably important, where as for a stock coil set-up it probably doesn't matter. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:33 PM |
