compression question, fun pulling things apart but... |
boiledcabbage |
Mar 13 2010, 10:29 AM
Member Group: Members Posts: 50 Joined: 23-May 05 From: Ottawa, Canada Member No.: 4,131 |
Hi - on my 74 1.8 removed passenger side head to remove something that fell in (!), removed some "carbon build-up" before replacing - pressure now is 115 front, 90 rear (while the drivers side is 120 and 120). Unfortunately did not check pressure before removing this head. Does anyone know if/how this will run with this low compression on one cylinder? Thanks for any advice.
(Suspect I should remove the head and have it done properly...) |
TheCabinetmaker |
Mar 13 2010, 10:37 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
It'll be fine(for a while). I've seen them continue to run with 50 all way round. Is the engine out of the car? If so, its a good time for a quick hone and ring change, while your getting the heads refreshed.
BMXerror |
Mar 13 2010, 07:55 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Probably a silly question, but you did use new head gaskets, right?
Mark D. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:52 AM |
