edwin |
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand ![]() |
Hey guys.
Been on here a while now but finaly have a 914 close to being on the road. It's a '72 but has a sideshift gearbox, 5 stud wheels (911 front not redrilled) and from what i can tell late doors with reinforcing along with the obvious RHD conversion to make life a little easier here in Australia. Hope these photos work. First some of the car a couple of years back. Attached image(s) ![]() ![]() ![]() |
edwin |
Now for the less exciting pics.
Previous owner tried to take out a pole. Thankfully made the car cheaper so i could buy it now i have to decide how to go about fixing. Off to a panel shop tomorrow to get their opinion and if the price is stupid i will do myself. Attached image(s) ![]() ![]() ![]() |
shoguneagle |
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California ![]() |
Glad you were able to purchase the car and possibly preventing it going to the "wrecking yard". Should not be any problem fixing the right front damage as long as the attachment points for the suspension and shocks are not damaged. Looks like the headlight box is were the damage is the structure. I double where the front part of the torsion bar attaches has any damage.
My car had damage more extensive to the left front corner pushing it back to the front trunk/fuel compartment divider; repaired and I had to do a little shimming on the front part of the left torsion bar. Got an excellent alignment and everything else checks out. It looks like a very nice conversion to RHD and it should give you many years of driving enjoyment. Steve Hurt |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,470 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I think I remember this car. The PO was a member on Club, or maybe Rennlist.
Zach |
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Very nice! It's good to see a RHD car in good hands... there aren't that many of them around.
edwin |
Conversion was done local by a guy who has a porsche wreckers so he used a proper RHD pedal box unlike some others i have seen.
it's had a few owners in the time i have known it, not sure if they were around on the club site or not. Fixing the front should be pretty easy as it hasnt marked the wheel well at all. only visible panel is the area next to the corner marker but it is pretty minor. the bumper reinforcing bar is crushed so i'm not sure if i would drill the spots and remove then weld back in when the front is straight or leave it all and try and pull it as is. Time is the big killer at the moment so if the panel shop is hapy to do the work i will probably just get them to do it so i have more time to work on the EFI and 2.0 Cheers guys |
stepuptotheMike |
medium pimpin ![]() ![]() ![]() Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States ![]() |
Welcome and you've got a gem there.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Super cool car.... buff it out and get it back on the road.. (IMG:style_emoticons/default/driving.gif)
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
My advice would be to use the existing head light bucket as a point to start your pull. You want to stress relieve the damage before cutting anything off the car. The inner panel the fender is welded to is stout. It is ver hard to pound out the crease in hte innner pan because the fender is totally in the way. I had to use a large rod with a BFH through the side light hole on Sandy's car.
Here's a couple photos of the same damage you have. ![]() ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I see the steering wheel is upside down, sign of a true southern hemisphere car ................
The Cap'n |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Good on ya Mate! I especially like that Beige interior like on mine - much cooler in hot climes! A couple of others looking at mine posted in garage on here, with similar damage to the opposite side (maybe a bit worse) have ssaid that pulling it on a Cellette Bench (or similar), then replacing the too far damaged parts with new/NOS or a good donor shell parts/sections was doable (primarily a light box & struts & maybe inner fender/well in my case). That's basically what Rick Ollah is saying above too, but don't know what shops down under will charge you for it? ... certainly more than a case of Fosters! (IMG:style_emoticons/default/biggrin.gif) Cheers & Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
Very cool!
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
AWESOME!!
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,821 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
I see the steering wheel is upside down, sign of a true southern hemisphere car ................ The Cap'n You beat me to it! What I want to know is is the gas pedal on the left side with the clutch on the right or is the cluster the same only on the other side of the tunnel? |
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
neilca |
Member ![]() ![]() Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 ![]() |
Conversion was done local by a guy who has a porsche wreckers so he used a proper RHD pedal box unlike some others i have seen. it's had a few owners in the time i have known it, not sure if they were around on the club site or not. Fixing the front should be pretty easy as it hasnt marked the wheel well at all. only visible panel is the area next to the corner marker but it is pretty minor. the bumper reinforcing bar is crushed so i'm not sure if i would drill the spots and remove then weld back in when the front is straight or leave it all and try and pull it as is. Time is the big killer at the moment so if the panel shop is hapy to do the work i will probably just get them to do it so i have more time to work on the EFI and 2.0 Cheers guys Edwin, Can you post a picture of your pedal box? I have made a RHD 914 and know the car was not originally built to be symetric. I was wondering how this was done by the rest of the world. Mine is a race car and I used the Wilwood pedals. Thanks, neilca |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
I see the steering wheel is upside down, sign of a true southern hemisphere car ................ The Cap'n thats so your foot doesn't get stuck when you hit the high beam! (IMG:style_emoticons/default/wacko.gif) only us old guys get that! (IMG:style_emoticons/default/biggrin.gif) nice car worth fixing (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 20th June 2024 - 05:43 AM |
