Any spark-plug readers in the house? |
SirAndy |
Apr 10 2010, 08:47 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Do these look OK?
I haven't been reading spark-plugs since my dirt bike racing days. On my bike, those would have indicated a slight lean condition. (IMG:style_emoticons/default/idea.gif) What about a 993 3.6L motor? Still too lean? Or OK? (IMG:style_emoticons/default/confused24.gif) Andy Attached image(s) |
TC 914-8 |
Apr 10 2010, 09:05 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Although I am far from an expert on FI engines They look lean to me
Here's a Link http://www.verrill.com/moto/sellingguide/s...gcolorchart.htm One other concern There is only 10 ? (IMG:style_emoticons/default/confused24.gif) |
Jeffs9146 |
Apr 10 2010, 09:22 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
If it was my motor I would not be upset!! Maybe a bit on the lean side but not too bad! How many miles??
SirAndy |
Apr 10 2010, 09:23 PM
One other concern There is only 10 ? Yo. I know that ... (IMG:style_emoticons/default/biggrin.gif) Two of the lower ones on the passenger side can only be removed with the engine dropped down about 2 or 3 inches. I'm going to do that next weekend, i ran out of time today. (IMG:style_emoticons/default/shades.gif) Andy |
SirAndy |
Apr 10 2010, 09:26 PM
If it was my motor I would not be upset!! Maybe a bit on the lean side but not too bad! How many miles?? On the old plugs? No idea. I actually never had them out. They were in there when i bought the motor, i just fired it up and it ran. (IMG:style_emoticons/default/biggrin.gif) Andy |
Jeffs9146 |
Apr 10 2010, 09:29 PM
Notice the darker tips, I think that is a good thing! Have you run it on a sniffer?
PS: Those are not cheep plugs!! |
McMark |
Check you distributor caps next time as well. (IMG:style_emoticons/default/wink.gif)
TC 914-8 |
Apr 10 2010, 09:32 PM
Here's an Idea, that won't cost too much. Being in Kalifornia, Stop by a smog test place (pass or don't pay) have them throw a sniffer up the tail and give you a reading.
All in all a bit on the lean side but burning clean. Especially not knowing the age. A new set of Bosch-4'2 or E2's and check them in a month. |
914werke |
Apr 11 2010, 12:39 AM
"I got blisters on me fingers" Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ha! I used to race a H1 and had to be an EXPERT at plug chop reading.
If it were me Id look for a little more tan than white, nut as others have said a little on the lean side but thats where the power is at! |
messix |
Apr 11 2010, 01:40 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
need closer shots of the insulator and the the tip of the electrode to tell you anything that would be of any worth. and pulling plugs out of a street car and trying to read rich or lean when it has idled is worth less for any judgement on full throttle mixture.
closer shots will show if there is any deposits on the insulator from detonation, and if the electrode is erroding from over heating from lean conditions. |
ChrisFoley |
Apr 11 2010, 05:24 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Unleaded fuel doesn't provide the same distinct color comparisons on spark plugs as the old leaded fuel did. As Messix noted, aluminum deposits and erosion are important telltales though.
We had some of the plugs out of the 3.6 in our shop last week and they looked much as yours appear. Have you put a scanner on the OBD2 to check for fault codes? Do you have the stock ECU chip or an enhanced performance chip? The performance chip in the car we have here tries to keep the AFR around 13.0 +/- 0.2, but the engine was lean and pinging at moderate load/low rpm until we replaced the O2 sensor. |
ME733 |
Apr 11 2010, 08:42 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
...............ANYTHING that WHITE is too LEAN.....look closely and you will find hard /melted/fused ..deposits....the plug tip is so hot it,s melting....Richen up the mixture before you burn a valve, hole a piston, or worse.........(needs a little more brown color to get "normal looking".)......and as mentioned check the oxygen sensor, a old or defective one will alter fuel mixture..+.check fuel filter..+..did you add race gas or an additive , drive awhile , before pulling plugs?........Ideas to consider. the chart in an earler post is Identical to the CHAMPION spark plug chart and is an excellant referance for spark plug condition..........
ChrisFoley |
Apr 11 2010, 09:02 AM
charliew |
Apr 11 2010, 11:12 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I agree also the resulting condition is from probably a idle period that doesn't show the rich or lean condition at wot or under a good load condition where det usually occurs and could cover up the small specks from det unless you use a loupe or magnyfing glass under a good light. The additives in unleaded gas in the different parts of the country make plug reading a problem unless it is done on new plugs at wot or under a load and immediately shut off. The air cooled motor is way more critical than a water pumper because the head temps vary so much. The sniffer at various rpms would be the easiest way to get real information or a afr gauge in the car all the time. The four seasons in the country will mean the fuel properties change more than we can keep up with on pump gas.
I think reading plugs is for racers that change plugs regularly and only run race gas. |
McMark |
Apr 11 2010, 11:23 AM
Yup, they're not that white.
Mike Bellis |
Apr 11 2010, 02:50 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Theres a guy in Concord with a dyno and lambda sensor. I took my last car there to tune the EFI. I think it cost me $200 for the day.
underthetire |
Apr 11 2010, 03:11 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Those look totally normal with Kalifornias alcohol content in the fuel.
VaccaRabite |
Apr 11 2010, 05:57 PM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Andy, do you have an Air Fuel Meter sniffing your exhaust? That will tell you much easier if you are rich or lean.
I am thinking about adding one to my little 4. Zach |
sixnotfour |
Apr 11 2010, 06:53 PM
914 Wizard Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
modern engine is smarter than you think.
McMark |
Apr 12 2010, 12:16 AM
Zach, it tells you if you're rich or lean, but it doesn't tell you if you too rich or too lean. 14:1 is almost never the right value. Especially with a modern motor. I'm sure you already know that, but for others who might be reading, I thought it was worth saying.
Lo-Fi Version | Time is now: 26th June 2024 - 03:11 AM |
